Author Topic: Nothing is ever easy, is it?  (Read 657 times)
Offline Katfish
  • 70 Challenger
« on: June 16, 2007 - 10:27:16 AM »
Thought I would do a simple project and switch my fixed fan to clutch style.  Well, it turns out the small fixed fan was on there for a reason.  Car has a 26" radiator, sounds good, but car should have the smaller radiator.  Turns out the radiator was shifted over towards the driver's side, no room for normal fan.
So, I had to take everything out and recenter the radiator.  Once this was done everything fits great.
On the plus side, I was able to pick up a brand new Mopar clutch fan for only $65 (shipping included).  Sometimes you can get good deals on ebay.
Offline cudabob496
Re: Nothing is ever easy, is it?
« Reply #1 on: June 17, 2007 - 05:49:35 PM »
Great looking engine bay!  On my 496 Cuda, I finally went to an aluminum radiator and electric fan. Rarely have to turn on the fan. Car runs 20 degrees cooler on average. And no mechanical fan means more horsepower.
2011 Kawasaki Z1000
Offline 74 340 4speed
« Reply #2 on: June 17, 2007 - 09:54:32 PM »
Looks good Catfish.  My car definately ran a little cooler when I did the fan swap and I noticed a few hp too.  How bout you? What brand aluminum radiator do you have cudabob496?  I'm on the look out for a replacement for my car.
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
Offline cudabob496
« Reply #3 on: June 17, 2007 - 10:17:29 PM »
I think for about $250 I went with a Howe. They had them in Summit, but one dimension wasn't right, so I called Howe directly and they fabbed it up for me at virtually no extra cost.
2011 Kawasaki Z1000
Offline Katfish
  • 70 Challenger
« Reply #4 on: June 18, 2007 - 04:05:56 AM »
Thanks guys, can't tell any difference in temperature, but I'm happy with the way it turned out.  It runs quieter, the fixed fan made the belts squeal, so this one must not be loading the motor as much.  I didn't have to loosen the belts to put it on, so the lack of noise is a good indicator.
« Last Edit: June 18, 2007 - 03:48:18 PM by Katfish »
