Author Topic: Anyone have a Chally with the rear glass currently out?  (Read 698 times)
Offline mikeinsjc
« on: June 17, 2007 - 10:10:56 AM »
When I replaced the sheetmetal between the trunk and rear glass, I failed to make note of the number and spacing of the clips used to hold the window trim on. If anyone can give me a count on the number of clips along the bottom and approximate locations I would be much oblidged. Thanks.
70 cuda
70 challenger
69 6 pack rr
Offline ksierens
    • 70 Challenger Resurrection
Re: Anyone have a Chally with the rear glass currently out?
« Reply #1 on: June 17, 2007 - 10:51:28 AM »
If you look up from inside the truck you will see the locations of the clip holes because there are holes in the deck shelf panel.
Kurt - SE Michigan
Offline mikeinsjc
« Reply #2 on: June 17, 2007 - 11:18:59 AM »
That's the piece of metal I replaced.
70 cuda
70 challenger
69 6 pack rr
Offline ksierens
« Reply #3 on: June 17, 2007 - 11:36:10 AM »
No, I mean the one inside the car, where the speakers goes, the one that your new extension panel is welded to in the window opening.   It has something like 1/4" holes in it for clearance for the trim screws.  If that doesn't help, I can get you the dimensions.
Kurt - SE Michigan
Offline mikeinsjc
« Reply #4 on: June 19, 2007 - 09:09:55 AM »
Yes, I see! Thanks for the that info.
70 cuda
70 challenger
69 6 pack rr
