Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
727 shift linkage
« previous
next »
Print
Pages: [
1
Author
Topic: 727 shift linkage (Read 1457 times)
daves70
Guest
727 shift linkage
on:
June 17, 2007 - 02:11:16 PM »
Ever since I put in my Harms pistol grip shifter, my shifter has been off. I have adjusted it 2 different times and it's still off. Last time I put the tranny in neutral, left the rod hooked up the the trans, had the adjustment bolt loose and put the shifter in neutral. then tightening down the adjustment bolt. Still not right. I tried un-hooking the rod from the trans the first time, putting the trans in neutral, then the shifter and loosening the adjustment bolt and dropping the rod into the hole and tightening. I was told that was the proper way. Not right.
Any tips???
Logged
tactransman
Sr. Resident
1973 Challenger- Member here since April 14, 2006
Re: 727 shift linkage
Reply #1 on:
June 17, 2007 - 06:46:16 PM »
Was it OK before the handle change?
Logged
Terry
-tactransman
Union, Mo.
daves70
Guest
Reply #2 on:
June 17, 2007 - 07:55:29 PM »
Yep.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
June 17, 2007 - 11:47:04 PM »
they can be tough to position just right , just undo the block on the lower arm & slide it a bit 1 way & see if it helps or get worse ,if it gets worse go the other way
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
727 shift linkage
