yup, I ordered the 16 blade MiraKool unit from FlowKooler last week. I received the 6-blade however.
Called them and they are sending the 16 blade.
The FK unit is pretty much identical to stock but has the disc installed and looks like the gasket area has been freshly machine surfaced. You wont find this quality of unit off the shelf at O'Reillys. It looks pretty easy to modify your existing WP, it has a thin galvanized steel disk that has been pop riveted to the impeller. Truthfully, it kind've looks cheap. I asked the owner how the pop rivets hold up being submerged and in a shear condition and he claims they haven't had any failures yet. They look like 1/8" dia rivets. Pop rivets seem like a cheap way to do this. Seems better to drill larger holes and tack weld the plate to the impeller hub. Maybe balance issues though?
Will report back my findings, its killing me to not at least bolt this 6blade on now and see if it improves my cooling condition.
