Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
Rear end gear weight?
« previous
next »
Print
Pages: [
1
Author
Topic: Rear end gear weight? (Read 732 times)
HemiDog
Sr. Member
Do not Assume!
on:
June 18, 2007 - 02:57:37 PM »
How would you determine what weight gear lube to use in the rear end?
I am running a 4.10, Detroit Locker in a Dana 60.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Rear end gear weight?
Reply #1 on:
June 19, 2007 - 01:45:19 AM »
Typiaclly use 80-90 but for better milage use 75-90 synthetic
Logged
rallyechall
Jr. Member
Reply #2 on:
June 19, 2007 - 05:50:36 AM »
Does the synthetic work with the LS additive? Is there another additive you need to purchase?
Logged
ShelbyDogg
Sr. Resident
Reply #3 on:
June 19, 2007 - 06:28:46 AM »
Herb McCandless brought this up on the power Tour. He said do not use synthetic gear lube with the clutch type posi units. It is too slick and will penetrate the clutches. Only use regular gear lube, then add the Mopar posi additive.
Last Edit: June 24, 2007 - 06:14:34 AM by shelbydogg
Logged
HemiDog
Sr. Member
Do not Assume!
Reply #4 on:
June 21, 2007 - 11:16:22 AM »
Thanks a lot guys!
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
