Author Topic: How far can you go on a 340?  (Read 5888 times)
Offline jeryst
« on: June 18, 2007 - 09:03:32 PM »
What's the most cubic inches you can get out of a 340? How far can you punch it out? Is there any type of stroker kit available?
Offline cudabob496
Re: How far can you go on a 340?
« Reply #1 on: June 18, 2007 - 09:12:27 PM »
I think 408 is as big as you want to go. Check out 440source.com
2011 Kawasaki Z1000
Offline matt63
« Reply #2 on: June 18, 2007 - 09:16:21 PM »
A 340 goes to 416 with a 4 inch stroke and a 0.030 overbore.  I've heard 500 hp is the limit with a stock block so more displacement would just help you exceed the blocks limits.  I met a guy at our Mopar meet who had the R3 race block and went with a bigger stroke resulting in about 468 ci if I remember correctly.  It was a custom crank and pistons.  He said his motor cost $20K.  He runs 10.5.
Matt in Edmonton
'68 Valiant
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #3 on: June 18, 2007 - 09:26:37 PM »
Mopar now offers a 440 small block that utilizes their new 340 resto block.
1996 Dodge Viper GTS Coupe
Offline jeryst
« Reply #4 on: June 18, 2007 - 09:31:36 PM »
I already have a 340 motor, so I would be using that. I believe its a 70.
Offline matts73cuda
« Reply #5 on: August 17, 2007 - 07:40:10 PM »
the most i have heard is 476 but that is on an aftermarker 340 block on a stock block i would only go to a 416 that is plenty
nivvy
« Reply #6 on: August 17, 2007 - 07:55:05 PM »
I have seen 474 strokers.....so 476 is probably right...
Offline Carlwalski
« Reply #7 on: August 17, 2007 - 08:02:05 PM »
:iagree: That is also what I have heard too, from a number of different people.  :thumbsup:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline go-fish
« Reply #8 on: August 17, 2007 - 10:53:56 PM »
You can meet all your needs with a properly built 416". That is unless your needs call for an R3 race block.
So, clearly you can get total self destructing cubes out of the engine, but what do want to do with it?
If you want to build it to the most c.i.d. then start with a race block. If you want to build it for max effort race then start with a race block. If you want a damn fine little screamer that can get you some low E.T.'s and not have a melt down backing out of the garage then get yourself a 4" crank and stoker pistons, bore it over .030 or .060. and invest in some good heads.
Offline matt63
« Reply #9 on: August 18, 2007 - 10:16:24 AM »
I was talking with a guy at our Mopar club who has a 461 cubed small block (340).  It is not an R3 block and he has run 9.74 in a 68/9 Cuda.  It has a 4 5/16" stroker crank.  Everything is custom built and he spent big $$$.  As far as I know. a 4" stroke is the biggest off the shelf stroker crank.
Matt in Edmonton
'68 Valiant
Offline go-fish
« Reply #10 on: August 18, 2007 - 11:32:55 AM »
Hughes Engines has a 426" Kit that has a longer stroke. I don't know what it is but he has them ready to ship. Also, does 440source do small block kits? I didn't think they did LA.
Offline jeryst
« Reply #11 on: August 18, 2007 - 09:31:49 PM »
A 426 small block? Cool!
