Author Topic: 4sp conversion  (Read 1572 times)
Offline cudachuck
4sp conversion
« on: June 19, 2007 - 05:10:59 PM »
hi i'm about to start my conversion and wanted to know if i need to take the dash out to do the pedal swap and does anyone have any advice for me thanks
Offline ShelbyDogg
Re: 4sp conversion
« Reply #1 on: June 19, 2007 - 05:34:15 PM »
Are you just changing the brake pedal and adding the clutch pedal?  That would be lots easier than putting in the whole assembly.   Having the dash out makes putting in the whole assembly  very easy.   Try the pedal route first.
Offline cudachuck
Re: 4sp conversion
« Reply #2 on: June 19, 2007 - 07:34:14 PM »
i got a brAKE and clutch assembly from brewers so i 'd take my old brake pedal out and put these in can it be done with the
Offline fantum
Re: 4sp conversion
« Reply #3 on: June 19, 2007 - 08:35:00 PM »
Yes, it can be done, and it is not very difficult.
I did it several years ago with my first Cuda and remember the hardest part was attaching the spring.  (Of course my back was a lot more flexible back then.)
fantum
Offline ShelbyDogg
Re: 4sp conversion
« Reply #4 on: June 20, 2007 - 05:44:20 AM »
Read this thread to put in the spring:
http://www.cuda-challenger.com/cc/index.php?topic=33766.0
Offline cudachuck
Re: 4sp conversion
« Reply #5 on: June 20, 2007 - 02:28:30 PM »
i was told i don't need the spring if i'm using a centerforce clutch is that true?? thanks
Offline ShelbyDogg
Re: 4sp conversion
« Reply #6 on: June 20, 2007 - 02:47:36 PM »
You don't use the spring with that pressure plate but you wont like the feel of it.  You might want to put a light spring on the over center mount just to pull your pedal all the way up to the bumper.
Offline cudachuck
Re: 4sp conversion
« Reply #7 on: June 20, 2007 - 06:40:21 PM »
would you suggest a better clutch ass. i was told centerforce was the best but this was comming from a ford guy.
Offline ShelbyDogg
Re: 4sp conversion
« Reply #8 on: June 20, 2007 - 09:30:59 PM »
I suggest the stock style borg&beck  Mopar Performance clutch with the 3 roller centrifugal assist. I have the McCleod brand, 10.95" with the 11" disk, behind my 440. The pressure isn't too stiff and the faster it spins the tighter it gets.   The wife can drive it and it never slips when I jump on it.
With this type, you can hear the rollers rattle when you shake the pressure plate. If you buy the scalloped 10.95" make sure you buy the bolts that go with it. They will either be small 12 point, 3/8 bolts, or 6 sided header type bolts.
Re: 4sp conversion
« Reply #9 on: June 21, 2007 - 12:42:36 AM »
I agree , I use B&B McLeod clutches , they aslo offer a Long style with less pedal pressure & adjustable centrifical weights
Offline cudachuck
Re: 4sp conversion
« Reply #10 on: June 21, 2007 - 05:02:39 AM »
do they make the mcloed long style for 10.5 flywheel thanks
Offline ShelbyDogg
Re: 4sp conversion
« Reply #11 on: June 21, 2007 - 05:50:06 AM »
Here is a link to Mancini's clutch page:
http://chucker54.stores.yahoo.net/mopper37.html
The 10.5" and the 11" Scalloped both fit on a 10.5" flywheel.  Make sure that you use the correct disk with each pressure plate;  !0.5 for 10.5, 11" for 10.95" scalloped.   They are a little pricey so try to find the same ones from McCleod, Jegs, or Summitracing.
You will need the big over-center spring but it aids in pushing it in and also in quick release.
« Last Edit: June 21, 2007 - 11:43:25 AM by shelbydogg »
Re: 4sp conversion
« Reply #12 on: June 21, 2007 - 10:49:57 AM »
Yes , it is a 10.95" & will bolt to the 130 tooth flywheel for maximum grip
