Author Topic: 440 six pack question  (Read 782 times)
Offline moparmuscle1970
  • Travelin' Man
« on: June 19, 2007 - 05:16:04 PM »
Okay, it is my understanding that the motors' horsepower ratings were lowered for insurance purposes. A 426 Hemi rated at 425 hp actually produced 500 hp, and the 340 six pack was rated at 290, but actually put out 350. Now, a 440 six pack is 100 cubes bigger than the 340(my great mathematical ability at it's finest), so is it reasonable to say that a 440 six pack puts out 450 hp? My 440 is not a true six pack motor, but is a magnum, is there any major difference? ps im trying to replace my double post and dont know how this is gonna work, so  dont get mad if you see this twice as im not sure how it will work!    thnks, mm
« Last Edit: June 19, 2007 - 08:35:15 PM by moparmuscle1970 »
1970 Barracuda- #'s matching
1970 Challenger- work in progress
1970 Plymouth Superbird- #'s matching (dad's)
Offline Andrew
Re: 440 six pack question
« Reply #1 on: June 20, 2007 - 12:39:02 AM »
The reason the 340 sixpack and 426 hemi were underrated so much was mainly because they were chryslers racing engines, the other engines wernt underrated so much as they didnt really need to be. Also, diff between a 440 sixpack and 440 magnum is the sixpack has 3 2bbl carbs on a special intake manifold. The 440 magnum had a single 4bbl carb on a 4bbl intake manifold, so the sixpack had more power than the magnum but about the same amount of torque.
  • Travelin' Man
« Reply #2 on: June 20, 2007 - 12:16:32 PM »
Thanks for answering about the racing motors, but what I meant about the difference between the magnum and six pack wasnt a question about carburetion-i have a six pack setup, including a 69 cast iron intake. I just thought that an actual six pack motor had different rods and maybe bigger valves. I'm pretty sure they use they same 906 heads though, right?
Offline ksierens
    • 70 Challenger Resurrection
« Reply #3 on: June 20, 2007 - 12:33:17 PM »
As far as I know the six-pack motor had a higher compression, and a forged crank.
Kurt - SE Michigan
Offline 6packCuda
« Reply #4 on: June 20, 2007 - 01:02:40 PM »
I believe they had different rods also.
  • Travelin' Man
« Reply #5 on: June 20, 2007 - 01:34:42 PM »
Also, about the 383 magnum. What makes it a magnum vs a regular 383? I was always under the impression that a magnum had 440 heads.
« Reply #6 on: June 21, 2007 - 12:45:52 AM »
Manguns had better cams , Exhaust manifolds , windage trays , valave springs etc , both 383 & 440 used the same heads
