Author Topic: Rev Limiter  (Read 1296 times)
Offline 6packCuda
Rev Limiter
« on: June 19, 2007 - 09:13:40 PM »
I'm running a MSD 6A ignition with billet distributer. Can I add a rev limiter to this set up, or would it be better to upgrade to the 6AL?
Offline cudabob496
Re: Rev Limiter
« Reply #1 on: June 19, 2007 - 10:14:57 PM »
I have the 6AL and billet dist. I suppose it would come down to cost to buy a rev limiter to add on, verses a new 6AL box.
Either way, in my opinion, the rev limiter is a must have. Good luck.
2011 Kawasaki Z1000
Offline Carlwalski
Re: Rev Limiter
« Reply #2 on: June 19, 2007 - 10:20:02 PM »
How do you add a rev limiter per-se? I wouldn't mind getting stuck into the Hemi but like any stick shift you run the trouble of getting stuck between N or missing a gear and I'd like to have the peace of mind knowing that if I F#$k up a shift the damage will be nil and the rpms will be fine. How do you set the rpm limit? Kind of like you would with a tach or something? I'd probably set mine to around 6-7K? Not sure. Very interested though. Any links to good "rev limiters"?
:popcorn: :cheers:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
Re: Rev Limiter
« Reply #3 on: June 19, 2007 - 10:36:50 PM »
 :popcorn: :popcorn:
since my factory tach is only a couple of thousand rpms off...I'm interested also.
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
Offline cudabob496
Re: Rev Limiter
« Reply #4 on: June 19, 2007 - 10:41:05 PM »
Think I saw some in Summit in the ignition section.
2011 Kawasaki Z1000
Re: Rev Limiter
« Reply #5 on: June 20, 2007 - 01:08:25 AM »
MSD does sell the rev limiter as a stand alone unit with wiring diagrams to work with virtually anything for under $100 but then you still have to buy the chip packs if you want anything other than 5000 or 6000 limit
Offline LAA66
Re: Rev Limiter
« Reply #6 on: June 20, 2007 - 07:16:54 AM »
 I recently purchased and installed an MSD limiter that works with the Chrysler electronic ignition. I has plug-in's for 4k,6k,7k, & 8000 RPM. The 4000 is for testing the unit I assume. So far all I get is a miss around that RPM which can be driven thru to a higher RPM. Really don't have the confidence in the system to install and try out the 6000 plug-in. MSD support has been helpful and I suspect my wiring is not putting out the correct voltage. As it stands right now I cannot trust my motor to this rev limiter  so it is disconnected.
Offline tactransman
Re: Rev Limiter
« Reply #7 on: June 20, 2007 - 10:27:02 AM »
This the one I am going to use. It has dials not chips,a two step rev control,cranking retard and a high RPM retard for NOs or a high compression engine. I have used it before and it worked great!
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD%2D6520&N=700+4294925127+115&autoview=sku
Terry-tactransman
Union, Mo.
Re: Rev Limiter
« Reply #8 on: June 20, 2007 - 10:36:28 AM »
You can buy the Crane box for 1/2 the cost , it does the same thing
Offline tactransman
Terry-tactransman
Union, Mo.
Offline tactransman
Re: Rev Limiter
« Reply #10 on: June 20, 2007 - 11:38:23 AM »
I don't think the Crane is a "two step" rev limiter. (staging RPM rev limiter and max RPM rev limiter) :dunno:
Terry-tactransman
Union, Mo.
Re: Rev Limiter
« Reply #11 on: June 21, 2007 - 12:44:16 AM »
That is what I have used in the past, not sure about the 2 step feature though
Offline Carlwalski
Re: Rev Limiter
« Reply #12 on: June 21, 2007 - 01:13:20 AM »
Terry, if I buy that, how do I know it will work with my Hemi?  I just want something that will limit the 540. I will talk to Tim the engine builder about it to see what is the ideal rpm for "cutoff"? but if I buy that box, what else would I need to run it, just the box?
Thanks, hope they made sense.  :cheers:
