I recently purchased and installed an MSD limiter that works with the Chrysler electronic ignition. I has plug-in's for 4k,6k,7k, & 8000 RPM. The 4000 is for testing the unit I assume. So far all I get is a miss around that RPM which can be driven thru to a higher RPM. Really don't have the confidence in the system to install and try out the 6000 plug-in. MSD support has been helpful and I suspect my wiring is not putting out the correct voltage. As it stands right now I cannot trust my motor to this rev limiter so it is disconnected.
