Author Topic: RPM tach, where to connect...???  (Read 2481 times)
Offline cowboy
  • Denmark
    • CowboyCars.dk
« on: June 20, 2007 - 03:51:53 PM »
Where do I connect the RPM tach, - this is my ingnition..
Offline 6packCuda
Re: RPM tach, where to connect...???
« Reply #1 on: June 20, 2007 - 03:55:40 PM »
Negative side of the coil.
Offline matt63
« Reply #2 on: June 20, 2007 - 03:55:48 PM »
This is typical:
    *  Red to 12-volt "switched" power supply
    * Black to ground
    * Green to trigger (negative side of coil, or tach output terminal if using an aftermarket ignition control)
    * White (or yellow) to light circuit
Matt in Edmonton
'68 Valiant
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #3 on: June 20, 2007 - 03:57:59 PM »
This is typical:
    * Black to ground
Is this : "an aftermarket ignition control"..???
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
« Reply #4 on: June 20, 2007 - 04:05:33 PM »
No, looks like someone upgraded it to the electronic ignition.
Dave :wave:
Worlds first e-body trailer.    Severna Park, Maryland
Offline matt63
« Reply #5 on: June 20, 2007 - 04:08:18 PM »
Correct!
Matt in Edmonton
'68 Valiant
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #6 on: June 20, 2007 - 04:12:59 PM »
OK, Ill try to find the wires.
- will there be a white or yellow one to ligth, it's a stock R/T dash..???
Offline matt63
« Reply #7 on: June 20, 2007 - 04:51:16 PM »
No.  The tach will have a white or yellow (probably white) wire which must be connected to a 12 volt power for back lighting the tach.  The tach will work without it. It must be connected to any 12 volt switched power source under the dash ie dash lighting source.  You can connect it to one of the terminals on the fuse box or to the same place as other after market gauges (if you have any) are connected to.  If you know the make of the tach the specific instructions may be on the internet. There are probably many choices of where this could be connected to but I'm not sure what is easiest.
Matt in Edmonton
'68 Valiant
« Reply #8 on: June 20, 2007 - 04:53:50 PM »
Are you trying to connect the original tach, or an after-market one? If it's the original, there are only 2 connections. The power wire goes on the long screw where my finger is pointing. I believe the wire is blue. The screw with a tab on it is where a wire from the "-" side of the coil connects. I believe that wire is gray. If you are missing, or can't find the wires, you can run your own. The ground connection for the tach is made from the contact with the metal housing that is screwed into the dashpad.
Offline JayBee
« Reply #9 on: June 20, 2007 - 06:01:13 PM »
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline matt63
« Reply #10 on: June 20, 2007 - 09:07:01 PM »
I ass-umed aftermarket tach :icon16:
Matt in Edmonton
'68 Valiant
Offline purple1
« Reply #11 on: June 21, 2007 - 05:19:55 AM »
Cowboy, In your thread about the heater problem you said the dash was changed to a R/T dash. Are you saying it was a standard dash cluster that was changed to a rallye dash cluster? If so you will have to add a wire for the tach, unless the dash wire harness was changed also. The standard dash harness will not have the tach hookup.
Dave :wave:
Offline IMNCARN82
  • LeDZeP
« Reply #12 on: June 21, 2007 - 06:36:54 AM »
i believe the rallye guages in my 73 'cuda are 70-71's. The factory tach is not working.There is an aftermkt. tach.  I've been looking for the connections to try and make the factory tach work. Thanks MEK !  I'll go dig around some more :working:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
