Author Topic: Main Stud girdles, worth it?  (Read 501 times)
Offline MyMopar
« on: June 21, 2007 - 09:54:28 AM »
Just wanted to get an idea.  I'm looking at building a 500" stroker 440 using the stock main caps and was wondering if the main stud girdle kits really are worth it at this level of build.  Does anyone have any feedback on this topic?  Motor will probably only make around 500 hp or so, never will see NO2.  The kit sells for $340ish if I recall.
1969 (OO===]|[===OO)
1973 (OO/=====\OO) <---SOLD
1997 (O|||||O) <---SOLD
Smoke tires, not drugs!
Re: Main Stud girdles, worth it?
« Reply #1 on: June 21, 2007 - 10:46:58 AM »
good insurance , generally used for 600 + hp though
« Reply #2 on: June 21, 2007 - 09:10:48 PM »
The 70 440 block I was useing made 785 hp and 690 tq. It was a 499. I used it race only and the block wasnt filled. I pulled the engine down every 30 or 40 passes or so. I did experience cap walk and used no girdle. I have since went to an aftermarket block with cross bolts. The engine makes a tad over 1000 hp and 780 tq now.
I'd say if you are racing your block and dont like maintenance, run the girdle. If your streetin and not into it for 9 secs or so at a time and launching at 5500 then you should be ok. But if you got it, run it. Like chryco says...good insurance.
Offline MyMopar
« Reply #3 on: June 22, 2007 - 07:18:34 AM »
THanks guys, not racing with the engine, just cruising.
