Author Topic: Quick Distributor Question - Help Needed  (Read 914 times)
Offline ViperMan
  • 2017 Carlisle or BUST...
    • JS Custom Cars
« on: June 22, 2007 - 01:54:09 PM »
Hey guys,
Haven't been around in a short while - I've been out every afternoon this week rewirin' my 'Cuda!
If I EVER find the guy who "fixed" the wiring when the alternator fielding circuit got fried, I'm gonna "fix" his arse...  I THINK that once upon a time, the (factory) electric choke wire dropped, touched the block and grounded the circuit.  Fried the crap outta everything.  I basically replaced every circuit that runs through the factory harness connector that sat at the back of the block on the passenger side.  The connector is gone - every wire runs straight from source to source.  If I wanted to get technical and really make a mess I could have ran individual connectors, but I didn't want that hassle.
Anyways, the reason for my post is that in rewiring the distributor circuit, I inadvertently loosened the adjusting screw for the inductive pickup of the variable reluctance sensor beneath the distributor cap.  I have no idea how much gap should be between the pickup and the star wheel.  I have a star point on the wheel pretty close to the pickup now, so if someone can give me an idea how far these should be apart, I can correct it pretty easily.  I'm HOPING there's not a precise thousands-of-an-inch measurement, or else I'm gonna need to run to sears and get a feeler gauge.
Any help is greatly appreciated.  Thank you.
Jeff
Re: Quick Distributor Question - Help Needed
« Reply #1 on: June 22, 2007 - 05:31:35 PM »
The ole service manual gives .008 inch gape between reluctor blade & pickup pole. measure using   NON-magnetic feeler gauge
« Reply #2 on: June 22, 2007 - 07:00:55 PM »
To the naked eye, it will just about look like it is touching. It's important though.  :grinyes:
Offline buzzard
  • Why is their AIR
« Reply #3 on: June 22, 2007 - 07:14:45 PM »
 :aarg: Hay 73 if your in a bind the cover from a book of matches about 8-9 thou. and it's non magnetic.
Offline ViperMan
    • JS Custom Cars
« Reply #4 on: June 22, 2007 - 07:35:36 PM »
Alright - thanks guys.  Gonna be a little more involved than I had hoped...
Thanks again.
Jeff
« Reply #5 on: June 23, 2007 - 12:22:47 AM »
only the last couple of years had the connector plug midway up the harness so the engine could be prewired & just plugged in once installed , 70-72 never had the extra plug
Offline ViperMan
    • JS Custom Cars
« Reply #6 on: June 26, 2007 - 05:39:59 PM »
Found a feeler gauge at Auto Zone with brass plates - one was a .008.  Worked perfect, runs great.  Thanks guys.
Jeff
« Reply #7 on: June 26, 2007 - 05:50:50 PM »
  :clapping:  :clapping:  :clapping:  :woo:
