Author Topic: Crush Can Puller?  (Read 6163 times)
Offline Samuelson1022
Crush Can Puller?
« on: June 24, 2007 - 12:26:40 PM »
Hi I'm a pretty young guy (17) and I have to pull the crush can off my steering column to get to the ignition, being the genius i am I used a screwdriver to try and pry it.  This didn't work to well, so I read up and now I need the puller.  Anyone know where i can get one? Thanks, Sam
Re: Crush Can Puller?
« Reply #1 on: June 24, 2007 - 12:35:45 PM »
You can borrow steering wheel pullers from many of the national parts stores,( Auto Zone, Advance) but you may have to adapt some longer bolts to reach into the depths of the crush can.
« Reply #2 on: June 24, 2007 - 12:43:53 PM »
You need a puller, NO doubt. I think they put crazy glue on them from the factory.  :stomp: I was lucky enough to borrow one from a guy at work that did the deal for me. I just remember a loud pop when it finally gave up the ghost.  :scared: The good news is, after you remove it that first time, anytime after that is a breeze, no puller needed.  :grinyes:
Offline 360 'CUDA
« Reply #3 on: June 24, 2007 - 01:17:58 PM »
I took an old puller and cut the ends off of it for the crush cans.  It fits in there nice and makes quick work of the job
« Reply #4 on: June 24, 2007 - 02:04:48 PM »
the puller costs 3.99 in most bargain bens at any and most all ato parts store :2thumbs:
Offline JayBee
« Reply #5 on: June 24, 2007 - 03:31:10 PM »
I ended up custom making a puller when things were slow at work.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline Scatterbrain
  • 1973 Challenger
« Reply #6 on: June 24, 2007 - 08:44:49 PM »
I used my harmonic balancer puller.  I think I paid 12 bucks for it and it pulls harmonic balancers as well as the crush can.
Offline willard
    • 1970 Challenger R/T
« Reply #7 on: October 24, 2011 - 09:48:49 AM »
Anyone knows whats the tread inside the crush can for two puller bolts? I have to order bolts for it (im in f... EU).
1970 383 R/T SE
Offline Grec
« Reply #8 on: October 24, 2011 - 01:00:56 PM »
"The good news is, after you remove it that first time, anytime after that is a breeze, no puller needed. "
Lol. That sure wasn't my experience. I recently pulled mine for the 2nd time and that frickin thing was on there so tight that I still got the loud pop that made me think I had snapped something. :-)
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline JayBee
« Reply #9 on: October 24, 2011 - 05:03:45 PM »
3/8 - 16NC. My Rimblow is inside now for winter storage so there was easy access to them. I even ran that tap into the holes to be sure. Here's a pic of my homemade puller.
« Last Edit: October 24, 2011 - 05:14:52 PM by JayBee »
John
2014 Toyota Avalon
« Reply #10 on: October 24, 2011 - 06:59:10 PM »
It can be done two ways
1] use or buy a small enough puller to get inside the can
2] use any puller but you need to get 7" long bolts & either a longer threaded rod to reach or a spacer that will slip over the threaded bolt  .
 JayBee is right the bolts are 3/8 coarse thread
Offline Katfish
  • 70 Challenger
« Reply #11 on: October 24, 2011 - 07:04:51 PM »
Does any kind of lube help with this, PB Blaster.................?
I tried in the past and gave up, that thing would not move!
« Reply #12 on: October 24, 2011 - 07:18:29 PM »
I doubt it.  Whatever they used at the factory was like cement.   :o  You need to have some type of puller. Believe me, you will hear a loud pop when it comes off too.   :22yikes:
Grec, I'm surprised you had problems pulling the crush can a second time. After I take the 3/4" nut off, I put the steering wheel back on the crush can with those 3 nuts...And pull. It works for me anyway.
Offline mopar12372
    • mopartech
« Reply #13 on: October 24, 2011 - 09:56:39 PM »
YES!~
RESTO PICTURES
Offline Strawdawg
    • Vortex Buicks
« Reply #14 on: October 24, 2011 - 10:12:25 PM »
edited out
« Last Edit: October 26, 2011 - 11:28:32 PM by Strawdawg »
