Author Topic: how would i find out if i had ????  (Read 498 times)
Offline cudachuck
« on: June 24, 2007 - 06:03:45 PM »
solid or hydrolic lifters in my 383 engine?i'm just wondering if i need to have them adjusted don't know much about engines yet is there a easy quick way to tell thanks
Re: how would i find out if i had ????
« Reply #1 on: June 24, 2007 - 09:40:28 PM »
typically you will have hyd lifters , pull a valve cover & see if the rockers arms are adjustable , depending on the covers on you ebngine you may be able to see through the oil fill hole
Offline cudabob496
« Reply #2 on: June 25, 2007 - 10:14:16 PM »
If it sounds like a bunch of marbles are rattling around under your valve covers, it's a solid!
2011 Kawasaki Z1000
