Author Topic: Passenger window ajustment  (Read 650 times)
Offline cuda-cable
  • MOPAR or no car
« on: June 25, 2007 - 10:00:07 AM »
 Folks what adjustment  do we have on the side windows, my window appears not tight at the front piller and needs adjustment in bound to kiss the weather strip  (new from soft seal) more snuggly. Right now you can see a gap. It appears my glass has a greater curve in it then the roof post.....thx..dk
Re: Passenger window ajustment
« Reply #1 on: June 25, 2007 - 12:16:03 PM »
at the bottom of the door there is an adjustment to tip the glass in or out at the top
Offline matt63
« Reply #2 on: June 26, 2007 - 01:28:23 PM »
CP The manual also says something about another adjustment if the bottom bolts don't allow more adjustment (I have this problem).  They talk about the regulator bolts.  Does adjusting here help ?
Matt in Edmonton
'68 Valiant
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
« Reply #3 on: June 26, 2007 - 01:39:09 PM »
The first two pics are on the bottom of the door. These control in and out tilt of the glass. The second two pics are on the top inside the door. They are guide felts that can be moved to apply more or less pressure out on the glass. Do not pinch them too tight to the glass. They can cause scratches if the fuzzy felts are worn out.
Cant kill the mean and ugly. Only the good die young...I plan to be here a while!!
Offline cuda-cable
  • MOPAR or no car
« Reply #4 on: June 29, 2007 - 09:56:50 AM »
thx for the input and pic's.........got er done and she works just fine.
