Here is the expenses to date. I have divided them into two categories. Items purchased from the fund and items charged on account for materials and some parts. There are still some more items to be added. I'm sure there will be some last minute items.
fishn
Purchased from the fund:
Fuel costs to pick up Cuda in GA and bring to OH $326.40
R & L trunk floor $178.00
L front floor pan $74.00
F & R seat covers $453.00
Front suspension kit $329.00
Trunk seal $24.00
Hockey stripe $69.00
Striker bolt $13.00
Timing cover gasket $26.09
Timing chain & gear set $26.62
Bypass hose $4.95
Water pump $29.77
Alternator $38.56
Oil pressure guage $15.28
Tires mounted and balanced $28.00
20 Chrome lug nuts $16.00
Small high torque starter $104.35
Hinge covers $96.00
(+) Battery cable $10.00
Steel cable for water valve $6.08
inline fuel filter $4.17
Thermostat $5.49
Thermostat gasket $0.81
Lower rad hose $10.35
Heater hose 1/2" $1.83
Upper rad hose $14.55
Dimmer switch $9.99
Voltage regulator $36.56
(-) Battery cable $12.71
PS belt $10.30
Alt belt $11.41
Ignition switch $42.59
Throttle return spring $8.37
Throttle bracket from Rick Erenburg $75.00
Heater hose 5/8" $4.91
Fuses $5.42
Vacuum hoses $2.16
Connectors and clamps $34.05
Additional items blasted $115.00
Misc bulbs $9.66
Misc screws, bolts, washers, and hardware $49.56
Trunk divider $25.00
Total Cost $2,357.99
CudaGuy Fund beginning Balance - $1,082.73
Cash donations for parts - $1,250.05
Balance (-) $15.21
Materials and addition parts on account
Sems plastic prep $14.16
10 Gal gas $30.00
Trans fluid 9 qts $20.61
Oil $11.38
5/16 fuel line $2.06
Seam sealer $27.00
Chassis saver $45.00
Premium undercoat $48.00
Variprime $40.00
Urethane primer $188.00
Base Coat and reducer $656.00
Clear and activator $230.00
Body fillers $150.00
Misc sand paper $82.00
Tape, paper, plastic $80.00
Sems black for interior panels $28.68
Aeresol paints
Satin black $39.00
Steel wheel $19.50
Rebuilders grey $6.50
Universal black $5.84
Engine enamel (Hemi Orange) $36.35
Misc colors $26.00
Gear lube and modifier $13.04
R & L calipers $41.80
Front pads $24.24
Spring kit $11.37
Adjuster kit $24.64
Rear shoes $28.00
(1) rear drum $33.31
(2) rear wheel cylinders $20.28
Brake fluid $3.99
Wheel bearing seals $5.75
Turn rotors and drums $34.00
1 wheel bearing $6.87
Halogen headlamps $17.15
Roll pins $.53
Vacuum fittings $5.40
Battery hold down $7.75
Brake booster $85.25
AC vacuum switch $49.95
Switch pod with good switches $25.00
Misc hardware $18.95
Total cost $2243.35
Cash donations for Materials and supplies (-) $710.00
Donations since 7-15-07 (-) $720.00
Donations given at Carlisle (-) $650.00
Balance $163.35
Adding in the materials, we are $208.56 in the red.
