Author Topic: Parts and Materials list with costs UPDATED 7-28-07  (Read 20503 times)
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
« on: June 26, 2007 - 10:04:30 AM »
Here is the expenses to date. I have divided them into two categories. Items purchased from the fund and items charged on account for materials and some parts. There are still some more items to be added.  I'm sure there will be some last minute items.
fishn
Purchased from the fund:
Fuel costs to pick up Cuda in GA and bring to OH      $326.40
R & L trunk floor                                                 $178.00
L front floor pan                                                 $74.00
F & R seat covers                                               $453.00
Front suspension kit                                            $329.00
Trunk seal                                                         $24.00
Hockey stripe                                      $69.00
Striker bolt                                      $13.00
Timing cover gasket                         $26.09
Timing chain & gear set                         $26.62
Bypass hose                                      $4.95
Water pump                                      $29.77
Alternator                                      $38.56
Oil pressure guage                                      $15.28
Tires mounted and balanced                         $28.00
20 Chrome lug nuts                         $16.00
Small high torque starter                         $104.35
Hinge covers                                      $96.00
(+) Battery cable                                      $10.00
Steel cable for water valve                         $6.08
inline fuel filter                                      $4.17
Thermostat                                      $5.49
Thermostat gasket                                      $0.81
Lower rad hose                                      $10.35
Heater hose 1/2"                                      $1.83
Upper rad hose                                      $14.55
Dimmer switch                                      $9.99
Voltage regulator                                      $36.56
(-) Battery cable                                      $12.71
PS belt                                                   $10.30
Alt belt                                                   $11.41
Ignition switch                                      $42.59
Throttle return spring                         $8.37
Throttle bracket from Rick Erenburg            $75.00
Heater hose 5/8"                                      $4.91
Fuses                                                   $5.42
Vacuum hoses                                      $2.16
Connectors and clamps                         $34.05
Additional items blasted                         $115.00
Misc bulbs                                      $9.66
Misc screws, bolts, washers, and hardware             $49.56
Trunk divider                                      $25.00
                                                    Total Cost     $2,357.99
                      CudaGuy Fund beginning Balance  -  $1,082.73
                                 Cash donations for parts  -  $1,250.05
                                                       Balance (-) $15.21
Materials and addition parts on account
Sems plastic prep      $14.16
10 Gal gas      $30.00
Trans fluid 9 qts      $20.61
Oil      $11.38
5/16 fuel line      $2.06
Seam sealer      $27.00
Chassis saver      $45.00
Premium undercoat      $48.00
Variprime      $40.00
Urethane primer      $188.00
Base Coat and reducer      $656.00
Clear and activator      $230.00
Body fillers      $150.00
Misc sand paper      $82.00
Tape, paper, plastic      $80.00
Sems black for interior panels      $28.68
Aeresol paints
Satin black      $39.00
Steel wheel      $19.50
Rebuilders grey      $6.50
Universal black      $5.84
Engine enamel (Hemi Orange)      $36.35
Misc colors      $26.00
Gear lube and modifier      $13.04
R & L calipers      $41.80
Front pads      $24.24
Spring kit      $11.37
Adjuster kit      $24.64
Rear shoes      $28.00
(1) rear drum      $33.31
(2) rear wheel cylinders      $20.28
Brake fluid      $3.99
 Wheel bearing seals                                            $5.75
Turn rotors and drums                                         $34.00
1 wheel bearing                                                  $6.87
Halogen headlamps                                             $17.15
Roll pins                                                            $.53
Vacuum fittings                                                  $5.40
Battery hold down                                              $7.75
Brake booster                                                    $85.25
AC vacuum switch                                              $49.95
Switch pod with good switches                             $25.00
Misc hardware                                                    $18.95
                                                       Total cost        $2243.35
              Cash donations for Materials and supplies     (-) $710.00
                                        Donations since 7-15-07      (-) $720.00
                                      Donations given at Carlisle      (-) $650.00
                                                           Balance        $163.35
Adding in the materials, we are $208.56 in the red.
« Last Edit: July 28, 2007 - 07:52:30 AM by fishn4cuda »
Cant kill the mean and ugly. Only the good die young...I plan to be here a while!!
Offline 4Cruizn
  • HEMI FISH
Re: Parts and Materials list with costs
« Reply #1 on: June 26, 2007 - 10:17:29 AM »
If I read that right, were about $1500 in the hole??   :clueless:
Offline RDF
« Reply #2 on: June 26, 2007 - 10:20:57 AM »
If so, I think it's 50/50 time........ :bigsmile:
Bob
1973 'Cuda
My build:
Offline Pistol Gripper
« Reply #3 on: June 26, 2007 - 10:28:34 AM »
I think we need to do fiddy / fiddy's  untill the materials AND labor is covered.
P.G.
O ne
B ig
A $$
M istake
A merica
Offline RDF
« Reply #4 on: June 26, 2007 - 10:30:08 AM »
P.G.
:iagree:
Bob
1973 'Cuda
My build:
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
« Reply #5 on: June 26, 2007 - 03:37:51 PM »
I have some cash for you, can I give it to you at Carlisle?
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
« Reply #6 on: June 26, 2007 - 03:45:07 PM »
No problem April.
Offline RusTy/SE
  • Just havin' fun
« Reply #7 on: June 26, 2007 - 04:09:56 PM »
fishn, did my donation arrive ok? :)
Russ :working:
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
« Reply #8 on: June 26, 2007 - 04:11:09 PM »
Russ :working:
Got it. :2thumbs:
Offline RUSTY Cuda
  • One big step foward!
« Reply #9 on: June 26, 2007 - 04:54:13 PM »
K, so far not as bad as my nightmares were, we are not that far off, I know there's still more to buy & do, keep the fund raising goin guys(& Gals)  get the final tally at carslie & hopefully we'll get back in the black or come up with some more ideas to get there! Pretty great job so far by all, I'm still amazed.
Offline 422STROKER
  • Member Since 6/3/06
« Reply #10 on: June 26, 2007 - 05:09:56 PM »
I'll have some $$$ in Carlisle for you Fishn.  BTW You are doing an unbelievable job.
Tom :money:
Maybe we can do a 50/50 at Carlisle?  Would they allow it?
Lots of people and a great story.  Start it Friday and have a drawing on Sun?   1/ticket who knows it could bring in some dough.  Could mail the winner a check so more people wouldn't have to be there on Sun. :2cents:
Tom
Offline whitesatinmopar
  • Member Since 3/30/02
« Reply #11 on: June 26, 2007 - 05:26:58 PM »
Want to have some fun at Carlisle ?  I gave Tony a little when we were up there over Father's day, but here is what I'll do.  Listen up : For a $5.00 donation you get to guess my weight and you can make as many donations and guesses you want. For EVERY $5.00 donation I'll match that up to the amount of my weight, in other words we could end up with the Dollar amount of my weight plus the donated amount. Or I'll donate a dollar for every pound I weigh, so if the donations are less (they better not be, ya hear) than what I weigh then I'll donate my weight in dollars.
Now if we'd get a couple other members  to do this, this may get settled up pretty d@mn quick  :roflsmiley:  I challenge others to do the same. To any who will do this with me................eat a lot between now and Carlisle.  :smilielol:
1969 Polara 500 vert.
1970 Charger 500
1971 Dart Swinger
1972 R/R 440+6 (wanabe)
1973 Challenger
Offline 4Cruizn
  • HEMI FISH
« Reply #12 on: June 26, 2007 - 09:41:21 PM »
I could charge for every dog I cook for the group?? Not that I want to though . .  because I know how expensive the car show food can be.   :scared:
  • Global Moderator
« Reply #13 on: June 27, 2007 - 03:51:33 PM »
That is a great idea too 4C.  I'd pay for your dogs anyday, I have never had better!
Now if we could get ourselves a strawberry smoothie machine...
  • Global Moderator
« Reply #14 on: June 27, 2007 - 03:52:35 PM »
I'm in for puttin in a guess.
