Author Topic: Dash Teardown  (Read 3351 times)
Offline kmyles
Dash Teardown
« on: June 26, 2007 - 11:29:03 AM »
OK..... I need a step by step process that I can take to take out my dash. :pullinghair: I am looking to take it all out and I already have the two nuts at either side off, gauges are out, ash tray is out. What would be my next step. I have to have it out tonight, she's going to the body shop tomorrow!!!! :cooldancing:
PLEASE HELP!!!!!!!! :feedback: :working: :working: :working: :working:
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Offline 4Cruizn
  • HEMI FISH
Re: Dash Teardown
« Reply #1 on: June 26, 2007 - 11:30:34 AM »
Is the windshield out??   :clueless:
Offline kmyles
Re: Dash Teardown
« Reply #2 on: June 26, 2007 - 01:08:39 PM »
No, it's not out..
_________
Kevin
Offline matt63
Re: Dash Teardown
« Reply #3 on: June 26, 2007 - 01:25:59 PM »
Steering column has to be dropped of course ( 2 nuts under the dash plus 3 bolts on the firewall under the dash).  I'm not sure if you can get at the screws along the front of the windshield with the glass in.  If you can get at them they are going to be a pain to get at.
Matt in Edmonton
'68 Valiant
Offline Carlwalski
Re: Dash Teardown
« Reply #4 on: June 26, 2007 - 01:34:43 PM »
There are about 10 3/8 nuts. The whole dash needs to be stripped to get at some of them. Remove the 3 bolts in the firewall/floorpan and the under dash bracket to lower the steering column. Two screws in each defroster vent, under dash at each side. Unplug wiring and remove. Unplugging the wiring is the hardest and the biggest pain in the arse. I think that covers everything.
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline 4Cruizn
  • HEMI FISH
Re: Dash Teardown
« Reply #5 on: June 26, 2007 - 01:44:48 PM »
NZ I don't think the dash has to be stripped to get it out . . if I recall correctly, I took the dash out of the convertible all in one piece and guages intact??  :clueless:   (could be wrong though  :drunk:)
Offline kmyles
Re: Dash Teardown
« Reply #6 on: June 26, 2007 - 01:48:39 PM »
The ten 3/8 nuts..don't they just hold the pad on. I want to take out the works!!!
_________
Kevin
Offline Carlwalski
Re: Dash Teardown
« Reply #7 on: June 26, 2007 - 01:49:11 PM »
Not sure what you mean Dave, maybe a misread on your part?  :clueless:
He needed (and I quote) "I need a step by step process that I can take to take out my dash." :cheers:
Offline Carlwalski
Re: Dash Teardown
« Reply #8 on: June 26, 2007 - 01:50:39 PM »
Yes but you can't brush your teeth without opening your mouth. ;)
There isn't just one large bolt and everything drops out, you have to remove it piece by piece.
There is no easy way......  :thumbsup:
Offline 4Cruizn
  • HEMI FISH
Re: Dash Teardown
« Reply #9 on: June 26, 2007 - 01:54:09 PM »
This was the part I wasn't sure about.  I know you need to take the dash apart to remove the dash pad in the car . . but I thought you could get the whole dash out of the car in tact without having to tear it apart?   :clueless:
Offline Carlwalski
Re: Dash Teardown
« Reply #10 on: June 26, 2007 - 02:00:29 PM »
LOL! :lol2: OK. Now I'm confused. :clueless: :smilielol: You only need to get to a couple as far as I'm aware, not all 10 of them. I've been reading up on it for the last week or so so I know what to do for Dads Cuda but obviously I'm no expert.
 :popcorn:
Offline kmyles
Re: Dash Teardown
« Reply #11 on: June 27, 2007 - 08:37:55 AM »
For those of you that may read this post at a later date, I figured it out last night: :clapping:
1) Remove gauges and disconnect wiring
2) Remove 4 screws in the ductwork, there is two on each side.
3) Drop the steering wheel
4) Remove the two bolts that are at either side of the dash, located next to the kick panel
5) Disconnect the wiring harness from the firewall.
And then pull you entire dash out!!! :eek4: :cooldancing:
Hope this helps someone elso out there and makes it a little easier for you than it was for me :2thumbs:
 :working:
« Last Edit: June 27, 2007 - 08:41:26 AM by kmyles »
_________
Kevin
Offline matt63
Re: Dash Teardown
« Reply #12 on: June 27, 2007 - 09:07:07 AM »
Was there no screws installed along the front of the dash?
Matt in Edmonton
'68 Valiant
Offline kmyles
Re: Dash Teardown
« Reply #13 on: June 27, 2007 - 09:48:35 AM »
Yes there were some screws along the edge for the light bar and for some of the trim, but that is fairly clear that it has to come off......:cheers:
_________
Kevin
Offline matt63
Re: Dash Teardown
« Reply #14 on: June 27, 2007 - 10:27:01 AM »
I meant along the bottom of the windshield where the dash meets the cowl.
Matt in Edmonton
'68 Valiant
