Author Topic: Dash Teardown  (Read 3355 times)
Offline kmyles
Re: Dash Teardown
« Reply #15 on: June 27, 2007 - 10:51:39 AM »
See step # 2 :cooldancing:
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Offline buzzard
  • Why is their AIR
Re: Dash Teardown
« Reply #16 on: July 01, 2007 - 07:10:50 PM »
 You have been dooing your homework. Printed off your inst. 27 minutes from start to finish. Thanks dude.
Offline kmyles
Re: Dash Teardown
« Reply #17 on: July 02, 2007 - 09:10:14 AM »
Excellent!!!!! Glad to hear it helped someone! :clapping: :clapping: :woo: :wow:
_________
Kevin
nivvy
Re: Dash Teardown
« Reply #18 on: July 05, 2007 - 02:38:34 AM »
WOW! I will be doing this real soon......I am afraid to start the project and I have all custom guages...did you leave the guages still in the dash when you yanked it all out???
Oops..sorry just read your post again...can you see the scews in the ductwork to remove or are the up in there alittle bit???
« Last Edit: July 05, 2007 - 02:41:57 AM by StrOkEr »
Offline kmyles
Re: Dash Teardown
« Reply #19 on: July 05, 2007 - 10:35:52 AM »
The screws you can see if you look down the windshield and they are in there, but like some other guys said earlier it is very doable. Good Luck with the tear down and lets see if you can beat buzzards record! :droolingbounce: :working:
« Last Edit: July 05, 2007 - 06:56:33 PM by kmyles »
_________
Kevin
Offline FY1 RT SE
Re: Dash Teardown
« Reply #20 on: July 05, 2007 - 12:30:17 PM »
For those of you that may read this post at a later date, I figured it out last night: :clapping:
1) Remove gauges and disconnect wiring
2) Remove 4 screws in the ductwork, there is two on each side.
3) Drop the steering wheel
4) Remove the two bolts that are at either side of the dash, located next to the kick panel
5) Disconnect the wiring harness from the firewall.
And then pull you entire dash out!!! :eek4: :cooldancing:
Hope this helps someone elso out there and makes it a little easier for you than it was for me :2thumbs:
 :working:
Car did not have a radio or speedometer cable in it?
Would have been easier to pull the dash with the cluster in it.
Offline kmyles
Re: Dash Teardown
« Reply #21 on: July 05, 2007 - 06:59:26 PM »
Radio I had already took out.....fairly easy to see that it has to come out anyway. A for the speedo cable see step 1...
And I prefer to take the gauges out anyway, so I can see what I'm up against and make sure nothing is going to catch during the removal....
kmyles :cheers:
_________
Kevin
Offline Lunchbox
Re: Dash Teardown
« Reply #22 on: July 06, 2007 - 08:35:48 AM »
Dont forget about the heater cable and vacuum lines if you have A/C.
Lunch
Offline 6packCuda
Re: Dash Teardown
« Reply #23 on: July 06, 2007 - 09:40:38 AM »
This may be a stupid question, but, how do you get the gauges out before removing the dash. :clueless: Is there a way of removing them from the front? :dunno:
Offline buzzard
  • Why is their AIR
Re: Dash Teardown
« Reply #24 on: July 08, 2007 - 07:48:04 PM »
 Magic tool Snap-On #SDDP162. Makes thoes 4 little ***** screws come out. This is a 16" #2 phillips screw MACHINE. I feel don't remove your guages etc. unless you want to damage them. It is so easy to remove the complete thing    as a unit. The side bolts were the last to come out. I'll take on all.                    Buzzard.
Offline kmyles
Re: Dash Teardown
« Reply #25 on: July 09, 2007 - 08:55:42 AM »
I Agree :2thumbs:
_________
Kevin
