Author Topic: Update on Electric Gremlins  (Read 10156 times)
Offline Mike71Cuda
Re: Update on Electric Gremlins
« Reply #30 on: July 28, 2007 - 08:19:52 PM »
Bullitt
jumped from + batt to bal got 12 but still got no strup tried dist in 3-4 locations still no good. Tried emailing you during the week but it bounced back. Can you email your ph # so I can confirm some things? My email is michael@maturehealth.com
« Reply #31 on: July 28, 2007 - 09:32:07 PM »
Mike, email sent
Wade
« Reply #32 on: July 29, 2007 - 06:55:00 AM »
Mike,
  Here's a test to see if your ignition switch is working. Unplug the connector going to the ignition module. Turn the key to the "on" position, and see what voltages you measure on the "+" side of the coil, and on one of the pins of the ignition module connector, you should have 12 volts.
Offline Mike71Cuda
« Reply #33 on: July 29, 2007 - 08:06:28 AM »
MEK
Thanks for the tip. I think I am good here. But I wll try anything at this popint to eliminate things.
Offline Mike71Cuda
« Reply #34 on: July 30, 2007 - 03:58:17 PM »
I have now drained my new battery while trying to turn the car over! javascript:void(0);
Pulling Hair
Could this be part of the bigger problem? javascript:void(0);
:clueless: Bullitt thx for your call, too.
Someone suggested dist. 180 out, but wouldn't I get backfire through carb? javascript:void(0);
Dunno
I know this is something simple, and after going through it I will have a wealth of knowlewdge on the subject but some of the variables are changing (voltage at bal res) javascript:void(0);
Chatting
« Reply #35 on: July 31, 2007 - 04:21:06 AM »
with the dist out 180* you will not nessisarily get a backfire out of the carb but it will not be happy
Offline Mike71Cuda
« Reply #36 on: July 31, 2007 - 08:14:33 AM »
Got batt. recharged last night so I will give it another shot tonight
« Reply #37 on: July 31, 2007 - 08:36:39 AM »
Mike, Use your timing tight, if you can get a signal , to check the dist. position like I said the motor doesn't have to be running.
Offline Mike71Cuda
« Reply #38 on: August 16, 2007 - 02:15:54 PM »
Now another problem!
I swapped out a bad balast resistor since I last posted.
Looks like that may have been one of many problems.
Here is the latest specs:
battery 12.26 V
bal. resistor 10.18 on battery side at rest
bal resistor on eng side 8.18 at rest
6.2-6.4 while cranking "run"
Spark off of coil so it looked liked everything was ok so I figure lets try and start it!
I made all of my connections and when I connected my quick-disconnect to neg side of battery I got a huge poip (sounded like a engine back fire-really loud even broght my wife out!)
disconnected batt. and saw plume of smoke near pass side firewall.
I then realized I left the key in the run pos. whiel I was making connections. What did I ruin! At first I thought I blew out the ECU (maybe I did). Then I considered starter or similar (bottom of engine is where I saw smoke). Want to ask you guys before I proceed and burn down the garage!
Smitty
« Reply #39 on: August 16, 2007 - 03:53:07 PM »
 ballasts can smoke when new
« Reply #40 on: August 16, 2007 - 04:51:21 PM »
Since you weren't trying to crank the engine at the time, all that happened was you applied voltage to the ballast resistor, which in turn fed the coil. I don't know what the noise was you heard, but if you didn't blow out the fusable linkage(doubtful), then I would try to connect the battery again. The fuseable linkage comes of the starter relay on the driver's side inner wheel well. It smokes a TON. Don't ask me how I know.  :misbehaving:
Offline Mike71Cuda
« Reply #41 on: August 16, 2007 - 04:52:58 PM »
Chryco,
Yes I know, had that with previous bal resist. But this was like a big block engine backfire.Smoke came from what appeared liek bottom of engine on pass side near ECU.
And bal was not even hot afetr the smoke cleared, which is why I am thinking it i snot it. A buddy told m eaI may have pinched a wire when installing Hemi and it is now grounding off and teh reason for my problems. My thought now is to go through the entire elec sysytem both in eng bay and and under dash. I was just hoping I could avoid this but it looks enevitable. Please add you thoughts
one step forward 2two steps back!
Smitty
Offline Mike71Cuda
« Reply #42 on: August 16, 2007 - 04:55:30 PM »
MEK
My first place to start with hunting down the entire system was the fusible link.
Could I have blown something on the fuse block as well?
« Reply #43 on: August 16, 2007 - 05:03:27 PM »
Now that I think of this more, I guess it's possible you gave the starter solenoid a jolt with connecting the battery with the key on. I still say try again with the key off this time   :poopoke: . If your starter doesn't turn, then you know what blew. I know you are scared now, but I don't think this is going to be tough to figure out.
Offline Mike71Cuda
« Reply #44 on: August 16, 2007 - 05:34:56 PM »
I am thinking with the large pop and smoke it is likely.
Hope to get back on the car after dinner, will keep you updated, thanks for your help
Smitty
