Author Topic: Can an Abody 833 be converted to an Ebody 833??  (Read 831 times)
Offline Challenger6pak
« on: June 26, 2007 - 12:33:12 PM »
I can't remember if the tailshaft can be changed or not.  Any help will be appreaciated.
Tod
Re: Can an Abody 833 be converted to an Ebody 833??
« Reply #1 on: June 26, 2007 - 11:35:35 PM »
yes & yes , I have an A body 833 OD that will bolt into your E or B body using a custom shifter mount , But the shifter comes through in the bench seat / forward position
 you can also swap the mainshaft & tailhousing to modifiy the 833 to long shaft using you existing gear set , the OD & normal 833 use a different mainshaft though so if it is a OD now you need an OD mainshaft for example
« Reply #2 on: June 27, 2007 - 08:57:50 AM »
I have an 833 OD from a truck here that is bad.  The case is broke.  It looks identical to my Ebody 833.  It even has the 2 shifter locations on the tailshaft which is iron instead of alluminum. I have an 833 Abody trans that is good.  Both are 23 spline.  What I want to do is use the Abody case and the Tailshaft of the broken trans and whatever internal components are needed to build a good Ebody trans. This can be done???
« Reply #3 on: June 27, 2007 - 10:00:39 AM »
if the case has the large front brg you can use the A body case & swap in all the OD parts from the track 833 OD
« Reply #4 on: June 27, 2007 - 04:20:34 PM »
Thanks Chryco.  I'll dig everything out and see what can be done.
Tod
« Reply #5 on: June 28, 2007 - 01:27:20 AM »
 :2thumbs:
