Author Topic: What oil pan will work in a 73 Chally.........  (Read 596 times)
Offline bandit67
« on: June 26, 2007 - 09:11:06 PM »
  Hi Guys, I am rebuilding a 360 I removed from a 76 Dodge Royal Monico for my 73 Challenger.  It has a  "center hung " oil pan which is what I think I need.  While looking at the oil pan in my 72 318 Charger, also a center hung, I noticed the pan had been stamped with one side flattened in order to give more clearance.  The pan with the 360 looks  "square"............question is , will I have any interferece problems if I use it in the Chally.  Am I explaining this right.......any ideas...........thanks ,,,,John
Re: What oil pan will work in a 73 Chally.........
« Reply #1 on: June 26, 2007 - 11:40:33 PM »
As you probably know the 318 & 360 pan are different , in most cases the center sump pans will fit unless it was out of a C body maybe , do you have a pan # ?
Offline bandit67
« Reply #2 on: June 28, 2007 - 01:26:58 PM »
  I assume , Chryco, you are referring the the three big numbers stamped on the pan.  I will see what they are and get back........thanks.......J
« Reply #3 on: June 29, 2007 - 12:23:20 AM »
Yup , the 3 BIG 3S stamped into the pan
