Author Topic: Ignition Wire Set  (Read 1884 times)
Offline patrick
Ignition Wire Set
« on: June 27, 2007 - 10:41:22 PM »
   With all the brand's and prices out there, what would be a good set for a 73 340 Challenger? Mopar Performence E.C.U. Advanced curve Dist. Blaster coil. Edelbrock Performer Intake, Carb. and Cam. Price isn't a factor but, Holy Cow! What's a guy really need? It's a sweet car but, not a drag racer. Way too many choices, need your help: Pat
Columbia Gorge 340 Rallye Dude
Offline ntstlgl1970
  • T a c o c a t
Re: Ignition Wire Set
« Reply #1 on: June 27, 2007 - 11:11:04 PM »
I think any name brand set routed correctly, kept away from hot areas like header tubes or exhaust manifolds while not rubbing on anything would be fine. Finding sets that work for a small block (since the wires come from the plug over the exhaust manifold) should be pretty straight forward.
« Reply #2 on: June 28, 2007 - 01:16:14 AM »
8MM spiral core wire would be my choice , Color preference may dictate make as different makes do offer diffeent colors
Offline buzzard
  • Why is their AIR
« Reply #3 on: June 28, 2007 - 06:19:56 AM »
 :canada: I like the MSD 8 mm wires.
Offline heminut
« Reply #4 on: June 28, 2007 - 11:02:44 AM »
Taylor wires have always worked well for me.
1970 5.7 Hemi Cuda
Online Bullitt-
« Reply #5 on: June 28, 2007 - 05:52:28 PM »
I have MSDs that were suppose to fit my 340 but several of the wires are too long. I contacted MSD & they sent terminals to install after cutting them to proper length, so if you go with them you might as well buy the kit to start with.
« Reply #6 on: June 28, 2007 - 06:08:18 PM »
My last 2 sets have been Taylor's "custom fit". If you go with a "universal fit" set, you will have to crimp one end on. I was lazy.  :grinyes: I didn't want to pay for a crimper. I agree that a few of my wires were a tad long, but I was able to route them thru the headers without any trouble.
Offline vinb
« Reply #7 on: June 28, 2007 - 06:34:37 PM »
MSD 8.5mm Super Conductor, universal fit black with gray boots...
Offline patrick
« Reply #8 on: July 01, 2007 - 12:27:26 PM »
  Thank's a lot guy's! :2thumbs:I had a fellow mopar nut look at what I had, he has a 70 440 Challenger. He say's I have a good set of Taylor's, Keep them! I'm pretty anal about what's in my car but, I guess if it's not broke, I don't have to fix it. Thank's again: Pat
Offline pandamarie
  • I love YaBB 1G - SP1!
« Reply #9 on: July 02, 2007 - 08:06:59 PM »
I used a set a msd 8.5 suuper conductors off my wifes vette, they fit perfect on the 440 six pack so if you want to save some money get the ready made wires for a 350 vette under the exhaust wire, vettes came over the valve covers or under the exhaust and they were cheaper than buying them for a 440. Now thats all I run on all my 60s and 70s cars. the older ones get Packard 440 solid core wire, if you dont run electronic ignigition this is the best no resistance at all.
1938 packard 120
1948 lincoln convertible coupe(1 of 16)
69 charger
70 challenger R/T 440 6 pac
71 challenger 340 R/T 4 speed
2-1961 nash metropolitans
forgive wifes 75 vette
2002 dakota 4.7
Offline patrick
« Reply #10 on: July 08, 2007 - 04:49:38 PM »
  Thank's for all the input guy's! I was down at my local N.A.P.A. store, picking one of the employee's brains. This guy is the happy owner of a 1970 440 Challenger R/T. He run's M.S.D. but, looked at mine and said I have Taylor's in there right now. "Keep them, they're in good shape! And they don't break down." I was concerned with them because, when changing my spark plug's over to N.G.K. Platnum's, I pulled one of the end's off. He set me up with some spare end's and told me to be more careful. Ooop's, I should have known better :dupe:Have a great day; Pat
« Reply #11 on: July 08, 2007 - 05:07:56 PM »
Don't fix what isn't broken, is a motto I sometimes follow.   :lol: If the ignition wires are bad, look for burn marks on the outside(they can short to any ground), or if the problem is internal, you will have a miss. Basically a wire will have high resistance at that point and not provide enough spark.  Ask me how I know.   :lol:
Offline patrick
« Reply #12 on: July 08, 2007 - 05:32:53 PM »
   I know, I know. Sometime's I try to fix thing's I think are broken, find out they weren't broken, but break them in the process of fixing unbroken part's. :clueless: :lol: Pat
« Reply #13 on: July 08, 2007 - 05:45:17 PM »
 I went to car quest and bought a 30 buck pair of wires for a 70 440-6. They were the correct lenghts and all fit just right for me. No misses.  Like yours, mine is just a daily driver. Point distributor too.
