Author Topic: Road Lamp Relay  (Read 1068 times)
Offline MR291
Road Lamp Relay
« on: June 30, 2007 - 05:57:05 PM »
I am adding road lamps to the Cuda and was wondering whether I really need the relay.  EBay has one on for $400.00.  There must be a better solution.
Recommendations?
Appreciate it.
Re: Road Lamp Relay
« Reply #1 on: June 30, 2007 - 06:22:41 PM »
What is your ultimate goal?  If originality is not crucial there are many relay/switch options to supply power, & I think a relay would be the best way to go for safety.
Offline FY1 RT SE
Re: Road Lamp Relay
« Reply #2 on: June 30, 2007 - 09:22:57 PM »
Recommendations?
Appreciate it.
'70 or '71?
'70 did not use the relay for powering on the lamps.
Re: Road Lamp Relay
« Reply #3 on: June 30, 2007 - 11:09:06 PM »
USe a $6 generic relay ??
Offline MR291
Re: Road Lamp Relay
« Reply #4 on: July 01, 2007 - 07:38:59 AM »
My ultimate goal is stay as close as possible to original, but $400.00 for a relay is not practical.  $6.00 is good.
Not being electrically competent (as per some of my other posts), would I be able to use  pretty much any relay so long as the leads match up or is there something more complicated to this.  I.E. I have a spare power window relay.  If the leads match up to the plug on the harness, can I simply plug this in?
I have attached a picture of my harness.  Also, would someone be able to tell me what plugs into what.
Single Dark Green = to lights
Double Green/Gray Plug = to switch
Double Green and Yellow/Black Plug = to relay
Red and Yellow/Grey Plug = to power (but where).  On steering column?
Single Pink?
Single Light Green?
Any suggestions would be appreciated.
« Last Edit: July 01, 2007 - 07:49:29 AM by MR291 »
Offline FY1 RT SE
Re: Road Lamp Relay
« Reply #5 on: July 01, 2007 - 09:26:46 AM »
I have yet to find a $6.00 relay that will work.  PW relay will not work.
Offline MR291
Re: Road Lamp Relay
« Reply #6 on: July 01, 2007 - 02:39:50 PM »
Great picture.
I'll track down a relay of some sort.
Thanks.
Re: Road Lamp Relay
« Reply #7 on: July 01, 2007 - 07:26:43 PM »
a relay is a relay , just a 4 or 5 prong 30 amp relay will work , it will not fit thew factory plug , 85 86 are the low powr termianls the 30 & 84? directly across from the 30 are the high amp termianls
