Author Topic: E-Body offset spring kit (SOLD)  (Read 973 times)
Offline Katfish
  • 70 Challenger
« on: July 02, 2007 - 07:46:03 PM »
SOLD
« Last Edit: July 04, 2007 - 05:30:59 AM by Katfish »
Offline VPOINTCUDA
  • Wish she were done so I could take her out Ridin!
Re: E-Body offset spring kit
« Reply #1 on: July 03, 2007 - 08:10:56 AM »
I'm interested, but when you say they move the springs closer to the frame do you mean inboardfor more tire clearance , or up tighter to the frame to lower the stance of the car? :clueless:
" the question isn't  when is he going to stop, but whose gonna stop him!"
« Reply #2 on: July 03, 2007 - 10:51:30 AM »
This kit moves the springs inboard in for more tire clearence, although with two mounting holes, it can also be used for lowering purposes.
If you want the springs in the stock location with the two mounting hole option for lowering, you'll need the adjustable hangers that I have listed elsewhere in this section.
Offline Katfish
  • 70 Challenger
« Reply #3 on: July 03, 2007 - 03:51:20 PM »
As mentioned, they move it inward for more tire clearance.  You can either use a stock b-body rear end, or move your e-body perches inward.  You gain 0.8" per side for bigger tires.
« Last Edit: July 03, 2007 - 04:10:29 PM by Katfish »
Offline 360 'CUDA
« Reply #4 on: July 03, 2007 - 03:58:56 PM »
I want 'em !!
Offline 360 'CUDA
Re: E-Body offset spring kit (SOLD)
« Reply #5 on: July 11, 2007 - 11:00:18 PM »
I got them!! That was quick  :grinyes:  Thanks!!!
