Author Topic: 489 Differential ??  (Read 695 times)
Offline cuda-cable
  • MOPAR or no car
489 Differential ??
« on: July 05, 2007 - 10:01:03 AM »
I've got a 73 Cuda....489 case diff, just got new sure grip and gears in it. FYI thou when they pulled it apart the pinion shaft is a 29 spline vs a 10 as apparently most are. Had to get another gear set to fit it and was available from Strange Eng'g in case someone else has the same problem. Folks at Richmond Gear only have the 10 spline parts.
Any advantage one to the other ,other than parts availability now 34 yrs later?
Offline tactransman
Re: 489 Differential ??
« Reply #1 on: July 05, 2007 - 11:27:31 AM »
Yup,the later differentials are 29 spline,they don't tell you to watch that when you order your gears,do they. ::)
Terry-tactransman
Union, Mo.
Offline matt63
« Reply #2 on: July 05, 2007 - 02:03:10 PM »
When you order gear sets I though you had to specify 741,742 or 489 due to different pinion shafts?  They are all different.
Matt in Edmonton
'68 Valiant
« Reply #3 on: July 05, 2007 - 09:22:07 PM »
They all have different size pinion shafts, but they also have coarse and fine spline choices. Just like four speeds.
« Reply #4 on: July 08, 2007 - 07:10:30 PM »
both style yolks are available in small or large U joint & usually if you have one the new gear set will be the other spline  :pullinghair:
