Author Topic: who carries black orangosol?  (Read 2348 times)
« on: July 05, 2007 - 07:57:05 PM »
My car is very close to finish now and I need to paint the lower black outs so I will be able to add the stripe on my barracuda
Offline RUSTY Cuda
  • One big step foward!
Re: who carries black orangosol?
« Reply #1 on: July 05, 2007 - 08:00:17 PM »
PPG has it, got it last week, the # the guy gave me is.........9355
        DCC low gloss w/ reducer hardener (no clear needed)
Funny thing is he corrected me & called it organasol, so double check with your guy, I had it spelled like you out of the chrysler resto book??????? Rich.
« Last Edit: July 05, 2007 - 08:02:53 PM by RUSTY Cuda »
Offline 71340RT
« Reply #2 on: July 05, 2007 - 09:07:03 PM »
That is correct it is ppg concept DCC 9355 and gets reduced 6 parts paint 2 parts reducer and 1 part hardner. The stuff looks great and is some tough stuff with the hardner. I used lacquer at first and had gas run out my filler tube and it change the color. That is when I took the lacquer off and put the concept with hardner on and have not had a problem with the spilled gas since. This is on my tail panel of my cuda.
Alan when you spray this stuff make sure you have a good respirator as this is some bad stuff if you inhale it. It will make you sick and I found out the hard way going in after I had sprayed the stuff a hour later and was sick for around 10 hours from the stuff.
Jeff
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
« Reply #3 on: July 05, 2007 - 11:25:29 PM »
Thanks for the advice. And also the part number for ppg. The whole bottom of my car from front to rear splash pans and tail panel has to be painted with this paint. Do you think a half gallon is enough? I wanna be sure to get it right the first time.....thanks ALAN
Offline 71340RT
« Reply #4 on: July 06, 2007 - 09:07:23 PM »
Hi Alan,
 The paint covers pretty good so I would think a half gallon would be enough wants you reduce it.
Jeff
« Reply #5 on: July 06, 2007 - 09:26:26 PM »
Hi Alan,
Jeff
Thanks Jeff, I'm going to try to get some this week coming up. I stopped by the body shop and they are ready for me...ALAN
