Stroker, locate a stock crush can, make an round piece of plate that you can bolt to it, then transfer the bolt pattern from your existing Grant wheel to the new adaptor plate. Drill and tap the holes, then drill a larger hole in the center of the adaptor for a horn wire. Simple and should cost you less than $20.
