Author Topic: Removing filler neck on '70 Cuda gas tank?  (Read 1912 times)
Offline drag-n-cuda
« on: July 08, 2007 - 05:16:15 PM »
Is there a secret to doing this?  Does the tank seal have some kind of band clamp that I'm not seeing.  Trying to remove now.
Quick, knowldgeable responses appreciated,
drag-n
Offline 6packCuda
Re: Removing filler neck on '70 Cuda gas tank?
« Reply #1 on: July 08, 2007 - 06:35:40 PM »
The neck should just slide out of the tank when you lower the tank.
Offline drag-n-cuda
« Reply #2 on: July 08, 2007 - 07:30:57 PM »
I got it out, it was just tough.  Does anyone now why I found a 6" long by about .75" diameter compression spring inside the tank?  Not a clue where it came from and what it would be used for.  Maybe someone who didn't like me put it there.
Thanks,
drag-n
Offline DAYLEY/CHALLENGER
« Reply #3 on: July 08, 2007 - 08:38:11 PM »
If I remember correctly.........back in the day when they started switching to unleaded gas , there were springs that were available to be inserted into the filler tube  for some reason.  I thought the unleaded nozzles were smaller that the leaded ones but I could be wrong.  Anyway.........It had to do something about the correct nozzle size with the correct gasoline.  I know this sounds confusing and it is........... :clueless: :screwy:
Dave or David
