Author Topic: A/C with SB Edelbrock heads??  (Read 1007 times)
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« on: July 09, 2007 - 10:38:18 AM »
Has anyone put A/C on a small block with Edelbrock heads?
I know the exterior of the heads are slightly different, so I was wondering if they needed special brackets to hook up the A/C components?  I was hoping to use the new Sanden compressor if at all possible.  Any ideas?
Thanks
Offline Mopar73340
Re: A/C with SB Edelbrock heads??
« Reply #1 on: July 09, 2007 - 02:07:02 PM »
If you are going to use the sanden compressor you will need a bracket for it so I would call Bouchillon Performance or check their website. www.bouchillonperformance.com.
Offline Jacksboys
« Reply #2 on: July 09, 2007 - 11:54:48 PM »
I never knew about them, I will check out their site, Thanks   :2thumbs:
Offline miketyler
    • www.miketyler.net
« Reply #3 on: July 10, 2007 - 07:29:56 PM »
the Bouchillion site is a good one for reference. If you dont see anything there that fits your needs, you can always make custom brackets like I did.
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline Jacksboys
« Reply #4 on: July 10, 2007 - 11:08:51 PM »
I was hoping to keep the installation simple and just bolt everything up.  I could make a bracket, but sometimes I feel like being lazy.   :2thumbs:
Offline Got JOB
  • Member since 2-14-06
« Reply #5 on: July 12, 2007 - 07:23:37 PM »
That is the kit I used for the brackets. If the heads have the bolt holes for the alt. bracket, I don't see any reason  why it would not work. Maybe catch you at the next cruise nite.
Ricky
70 T/A Plum crazy
71 vert. viper red
74 Rallye triple black ( sold )
76 Aspen Wagon
West Georgia
Offline Jacksboys
« Reply #6 on: July 12, 2007 - 10:24:31 PM »
Ricky
Thanks for the pic.
The heads have the bolt holes but they have a slightly different offset since the heads are flat on the ends.  This is why I had to go with the rounded alt, plus I had to add a few washers to make everything line up straight.
Maybe at the next cruise.   :2thumbs:
