Author Topic: 73 chally  (Read 832 times)
Offline ICEMAN
  • I'm a llama!
73 chally
« on: December 07, 2003 - 07:19:37 PM »
I have a 73 challenger ralley I need a 4 speed council is it possable to use one from a automatic Thanks Andy
Offline 360 'CUDA
Re:73 chally
« Reply #1 on: December 07, 2003 - 10:28:14 PM »
The console seems to be the same but the upper plate
hole for the shifter is quite a bit bigger on the four speed then on the auto
Re:73 chally
« Reply #2 on: December 08, 2003 - 01:05:50 PM »
there is a notch in the bottom lip of the console so there is clearance for the shift boot so it doesn`t get torn
Offline Pistol Gripper
Re:73 chally
« Reply #3 on: December 08, 2003 - 07:29:26 PM »
Hi,
You can use an auto console if you make a new top plate out of thin wood or metal.  The hole for the shifter is larger and in a different location. The openning in the plastic top half of the console seems to be the same.  If you cut a top plate out of metal, wood grain decals are plentiful and you can use it as a template.   The notch in the side of the bottom half would be a bit harder without a real one to copy.
Hope this helps,
P.G.
O ne
B ig
A $$
M istake
A merica
