Author Topic: Power Windows  (Read 2002 times)
Offline MR291
Power Windows
« on: July 09, 2007 - 07:23:50 PM »
Hi,
I am putting power windows in my Cuda.  The question is where does the harness exit from the door and enter into the side of the firewall.  On the drivers side there is a hole for the mirror bracket and a large dimple on the firewall above the kick panel.  Right area?
Second question is whether there is an after market harness that I can use.  Does not have to be perfect but hopefully runs the same amount wires and hooks up to the stock switches.
Appreciate it.
Offline miketyler
    • www.miketyler.net
Re: Power Windows
« Reply #1 on: July 10, 2007 - 09:31:59 AM »
I used the dimples as locators. I went to the wrecking yard and got some S-shaped rubber conduit/boots to use for mine. They were accordian style and worked out pretty well.
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline MR291
Re: Power Windows
« Reply #2 on: July 10, 2007 - 07:38:34 PM »
Hi,
I will drill out there as well.  What did you use for a harness?  Do you have any pictures of your install?
Thanks.
Offline miketyler
    • www.miketyler.net
Re: Power Windows
« Reply #3 on: July 10, 2007 - 08:36:29 PM »
I think the rubber boots came out of a compact Ford. I used Electric Life regulators and OEM switches so they look original. I had to make up my own harness and patch it into to a new accessory fuse block
« Last Edit: April 28, 2014 - 08:57:34 PM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
Offline MR291
Re: Power Windows
« Reply #4 on: July 11, 2007 - 04:55:19 AM »
Thanks for the pictures.  I'm going to do something similar.
Offline CudamanTom
Re: Power Windows
« Reply #5 on: April 16, 2014 - 09:30:48 AM »
I realize this post is several years old but the pics are gone and I'm needing help.
miketyler (or anyone else) can you please repost pics of what you did for the wiring harness under the dash that is patched into the fuse block and goes to each side. I have all the wiring harness for each window except the part under the dash to each side connectors.
Thanks,
Tom
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline miketyler
    • www.miketyler.net
Re: Power Windows
« Reply #6 on: April 28, 2014 - 07:06:31 PM »
Let me see if I still have pics
72' Cuda restomod
70 Mustang Mach 1
Offline CudamanTom
Re: Power Windows
« Reply #7 on: April 28, 2014 - 07:51:37 PM »
Thank you!!!  :2thumbs:
Offline ragtopdodge
Re: Power Windows
« Reply #8 on: May 12, 2014 - 12:37:11 PM »
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline CudamanTom
Re: Power Windows
« Reply #9 on: May 12, 2014 - 12:45:31 PM »
Thanks Ragtop,
But I have both door/hing point wiring.
I was inquiring about the wiring under the dash that goes to each side.
Offline ragtopdodge
Re: Power Windows
« Reply #10 on: May 16, 2014 - 03:41:36 PM »
Bill and Rose evans repro's the underdash wiring.
E Body power window accessory harness    $150.00
http://www.evanswiring.com/catalog.htm
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline CudamanTom
Re: Power Windows
« Reply #11 on: May 16, 2014 - 05:44:24 PM »
That will work.  :2thumbs:
Thanks Ragtop.  :wave:
