Author Topic: Rewiring the 'Cuda - DONE - Price List  (Read 33597 times)
Offline RDF
  • The pain that greets me is the stick that beats me
Re: Rewiring the 'Cuda **Updated 7-26-07**
« Reply #30 on: July 28, 2007 - 12:31:17 PM »
You need to supply bulb connections so far from what we've found, which is a little  :eek4: havin to track em down. Ring/spades too  :cheers:
Goody,
We still on for tomorrow, 7am?
Bob
1973 'Cuda
If we never drown we'll never know how well it tastes....So tell me how it tastes and I'll know just how well you drowned.
My build:
http://www.cuda-challenger.com/cc/index.php?topic=45749.0
Offline GoodysGotaCuda
« Reply #31 on: July 28, 2007 - 01:00:49 PM »
Goody,
ill get there about 715  :thumbsup: ill be in the truck, Cuda's tires are dangerously dead after last nights adventures  :lol:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline shatar4
  • 71 Challenger
« Reply #32 on: July 29, 2007 - 04:56:09 PM »
Can you use that kit with you stock switches (headlight, dimmer, wiper)?
1971 Triple black 340 Challenger
« Reply #33 on: July 29, 2007 - 06:35:54 PM »
...we'll find that out. lol. kit insturctions do not cover those at all. we need to contact EZ and see what they say as far as that goes.
1976 Dodge Warlock
Offline 4Cruizn
  • HEMI FISH
« Reply #34 on: July 29, 2007 - 10:56:00 PM »
 :eek7:   :eek7:   :eek7:  That is not for me.  I would definitly look like this - - >  :pullinghair:   :banghead:
Offline RDF
« Reply #35 on: July 30, 2007 - 08:57:05 AM »
Ok, Rule #1......NEVER touch a soldering iron when it's HOT!!!  As you can see from the pics below, 2nd degree burns are the result.  Other than that, we made good progress....the tail section is 99% complete and the front harness is about 75%.  I've ordered my gauges and hopefully they'll be in later this week so I can start that process as well.  All in all, things are going ok, just a lot of tedious things that make the whole process long and drawn out.
Bob
1973 'Cuda
My build:
Offline gomopar440
« Reply #36 on: July 30, 2007 - 09:04:57 AM »
That's how the last two Painless kits I did went. You have to connect the appropriate wires to all the stock switches. I'm not sure about their new Mopar specific kit though.
EZ appears to be the same as far that goes from what I've seen with my EZ-21 kit. You should be ok as long as you have good wiring diagrams to go with the EZ kit directions. Here's a good link if you need any Mopar wiring diagrams (You may have to be a registered user on the site to view them though): http://www.moparnuts.com/forums/view.php?pg=wiringdiagrams It covers all 1967-1973 Mopars.
« Last Edit: July 30, 2007 - 09:06:51 AM by gomopar440 »
« Reply #37 on: July 30, 2007 - 06:41:27 PM »
 8)
1976 Dodge Warlock
Offline RDF
« Reply #38 on: July 30, 2007 - 06:48:16 PM »
Bob
1973 'Cuda
My build:
Re: Rewiring the 'Cuda **Updated 7-30-07** - OUCH!!!!!
« Reply #39 on: July 30, 2007 - 06:59:32 PM »
Does your soldering iron not have a handle?  :poopoke:  :poopoke:
« Reply #40 on: July 30, 2007 - 07:38:02 PM »
How the heck did your starter relay & ignition box get under the battery?  Doesn't seem like the most convenient or hospitible place for them.
« Reply #41 on: July 30, 2007 - 07:42:03 PM »
Because i got to him lol, not quite something you use/tinker with everyday  :dunno:, his voltage regulator is on the radiator support too.
1976 Dodge Warlock
Offline 422STROKER
  • Member Since 6/3/06
« Reply #42 on: July 30, 2007 - 07:45:40 PM »
Maybe you should have gotten one of those "Cold Heat" Soldering Irons..LOL :rofl:
BTW looks good, I used to have my MSD under the Battery Tray before, cleans up the bay while doing so.
Tom
Although the Starter relay isn't weather tight.
Tom
Offline Devil
  • Forward, Together Forward
    • Ryan's Cars in Barns
« Reply #43 on: July 30, 2007 - 10:14:23 PM »
It is very dangerous to have those in those locations.  They can easily get way too much moisture up there and have a high likelyness to fail/short out.  Ever wonder electrical items are in back/upper sides of the engine bay?... To stay away from water.  I would move them out of the way as soon as possible.
Then again, if Goody is helping you, I expect nothing less.
Ryan
http://www.flickr.com/photos/hemipwr70/
http://carsinbarns.blogspot.com
71 Challenger R/T Clone
69 Charger R/T SE
70 Barracuda
74 Dart Swinger
93 RamCharger
88 Caprice Classic Brougham
« Reply #44 on: July 31, 2007 - 04:54:33 AM »
Ryan
Neither one of us quite say, its raining, ill go for a cruise. Given that, and the fact my stuff has been moved for about a year and a half on my car, even with a kill switch IN my inner fender with no problems. Yes, I've been in more than enough rain too. He won't have an issue. Also maybe part of the reason they put things where they did is maybe partially for mass production reasons? These engine bays were not designed to 'look clean and pretty' with their locations of electrical components. To compare his electrical system from how it was, wire nuts, open twisted splices, cut insulation, etc. The locations of those components is nothing near 'very dangerous'. Last time I checked when it rained, I didn't have any water except a minimal amount that made it through the fan. And this IS florida, it RAINS. Unless RDF decides he will cross a small flowing river, he will be more than fine.
Given the nature of that last little comment, 'Then again, if Goody is helping you, I expect nothing less.' Nor do I expect nothing less from you to take a fine situation of him in need of rewiring his car and me helping him. You are in no place to say my help is inadequate or 'very dangerous'. Same old stuff from you, either here or moparts.
« Last Edit: July 31, 2007 - 04:58:42 AM by GoodysGotaCuda »
1976 Dodge Warlock
