Author Topic: 72 Challenger roof help me please!!!!!!!!!!!  (Read 2183 times)
Offline mopar#1
« on: July 12, 2007 - 06:13:17 PM »
I thought maybe you could see factory marks to remove the roof skin but I dont see any. My car had a black vinyl top but after the tree fell on it I removed it. :crying: I just wanted to see pics of the roof skin being removed so I dont screw mine up taking it off. ??? Has any one replace sections of the roof supports and if so could you show me pics on that too. I am green on body work. I will post pics so you can see. thanks for all the help
p.s. any thing you guys and gals would like to add would be great. :1zhelp: Thanks again mopar#1
P.s.s. if anyone knows where I could find parts for this in nwIowa or tristate area that would be cool too. :bigsmile:
72 challenger
83 Ram 150 custom
96 Neon
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
Re: 72 Challenger roof help me please!!!!!!!!!!!
« Reply #1 on: July 12, 2007 - 07:05:07 PM »
This pic should help get you started. Looks like it's time to buy a spot weld cutter too. Good luck on your project.
Dave :wave:
Worlds first e-body trailer.    Severna Park, Maryland
Offline moparclown
« Reply #2 on: July 12, 2007 - 07:14:57 PM »
Trust me that is a s!%#load of work,especially if your new to bodywork.
« Reply #3 on: July 12, 2007 - 07:30:55 PM »
First,...buy a chainsaw.
Offline purple1
« Reply #4 on: July 12, 2007 - 07:45:20 PM »
:roflsmiley: Yea that'l help....  :misbehaving:
Any way Topcat's just foolin with ya...  :poopoke:
Mopar#1, the Clown is right.
Dave :wave:
Offline SilverChally
« Reply #5 on: July 12, 2007 - 08:29:36 PM »
You need more than just a skin!
70 challenger project
68 satellite
Offline jeryst
« Reply #6 on: July 12, 2007 - 09:16:41 PM »
You are better off just replacing the roof. You can usually pick up a nice one for around $200-$400. I'm facing the same thing because mine is rusted through in several places becaues of the vinyl roof. The guy that is going to do my bodywork said he will just take it off at the seams and put the new one back on.
Offline DMZ73
    • http://www.pbase.com/dmz73/
« Reply #7 on: July 13, 2007 - 08:56:03 AM »
I can definitely help you out in all aspects of this project.
It's not as bad as people make it out to be, its just a question of how methodical you are. There are TONS of factory spot welds, maybe somewhere in the realm of 500.  First, remove all of your trim, your windshield, and your interior/seats. Remove the body seam caulk and melt out/ remove the lead covering the factory roof seams. Locate your spot welds and center-puch them. Purchase a Rotabroach spot-weld cutter and start drilling through the welds.
Now your skin can be popped off - if you want to go that far - I needed to due to severe rust. You may not need to. You only may need to replace sections - which is a lot easier.
You can see my process here:
A-pillar seam: < http://www.pbase.com/dmz73/image/67929537 >
C-pillar seam: < http://www.pbase.com/dmz73/image/67472516 >
another shot: < http://www.pbase.com/dmz73/image/67929721 >
Roof removed: < http://www.pbase.com/dmz73/image/67929548 >
                    < http://www.pbase.com/dmz73/image/67929565 >
Donor Roof skin alone: < http://www.pbase.com/dmz73/image/72546223 >
After some fabrication, cutting, welding, rough shaping, much drilling, some filling and planishing, - (i.e. fine dent removal) prime and temporary paint
This is how it looks: < http://www.pbase.com/dmz73/image/79164807 >
I bought a donor roof (structure and skin) for 150. I just used it for the skin, but you need it for pieces of both.
I have a spare structure in its entirety I will be getting rid of. See my pics for more info...
This is the Donor structure I still have: < http://www.pbase.com/dmz73/image/72558284 >
If you want to do it in sections, its really easy. Just make sure you cut out far enough past the dented structure so that the donor sections can be grafted in properly.
If you have any othe rquestions, don't hesitate to ask.
Best regards,
Dan
« Last Edit: July 13, 2007 - 09:04:57 AM by DMZ73 »
Offline Black340
  • 1973 challenger 340 4 Speed
« Reply #8 on: July 13, 2007 - 09:14:05 AM »
Dan, I don't have the problem that Mopar1 has, but your photos and explanation are great..thank you
Offline mopar#1
« Reply #9 on: July 13, 2007 - 11:26:59 AM »
DMZ73 thanks for your info that will help me out alot. What might you use to put it back on far as welding and covering up the weld spots and seams. Just wondering if you would want to sell the frame supports and if you could ship. If not let me know and thanks again for all your help.
p.s. I will post more pics so you can see damage better if you would like.
72 challenger
83 Ram 150 custom
96 Neon
« Reply #10 on: July 13, 2007 - 11:32:13 AM »
The inner structure is bent, your better off as mentioned replacing the complete roof.  Probally less work too!
68 satellite
Offline mopar#1
« Reply #11 on: July 13, 2007 - 12:05:09 PM »
I have one more Qs. Should I support the front, middle, and rear of the car so it dont start to sag when  cutting the roof supports off. Thanks again mopar#1
72 challenger
83 Ram 150 custom
96 Neon
Offline 360 'CUDA
« Reply #12 on: July 13, 2007 - 12:17:28 PM »
Absolutely.  Also you would want to place several jackstands all over the bottom to equalize the pressure.  Of course a rack or flat table that the chassis rests on would be best but not everyone is Boyd or Chip so.....
« Last Edit: July 13, 2007 - 12:24:16 PM by 360cuda »
Offline mopar#1
« Reply #13 on: July 13, 2007 - 12:26:05 PM »
360cuda thanks for the info. That is what I thought but didnt know. Thanks again mopar#1
P.S. sweet car
72 challenger
83 Ram 150 custom
96 Neon
Offline dougs bs23
« Reply #14 on: July 13, 2007 - 01:50:39 PM »
 :iagree:  be easier than trying to reskin and repair pillars
