Author Topic: What am I in for???  (Read 4834 times)
What am I in for???
« on: July 15, 2007 - 09:40:42 AM »
In attempting to figure out my carb problem, I have unearthed a real ugly monster.  :scared: If I put the car in drive, the engine revs, and it goes nowhere. I can put it in first, and manually shift up to third, and reverse works too. Keep in mind this was my best diagnosis limping home about 1.5 miles this morning. Also note there was some real scary noises coming from the tranny for a few seconds once it did start moving. So I know some damage was definitely done. I had this tranny rebuilt 3 years ago. I have NO clue about trannys, so I will have to take this some place. My question is, what am I in for, another rebuild, or might I get lucky and just need a new thingamajig or doo-hickey?  :dunno:
EDIT: The tranny fluid looks good, and doesn't smell burnt.
« Last Edit: July 15, 2007 - 09:53:58 AM by MEK-Dangerfield »
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
Re: What am I in for???
« Reply #1 on: July 15, 2007 - 09:49:29 AM »
Oooo Nooo ...  :banghead: Doesn't sound like you will make the Nats. Maybe get another trans and swap them would be the quickest way for now.
Dave :wave:
Worlds first e-body trailer.    Severna Park, Maryland
« Reply #2 on: July 15, 2007 - 09:54:44 AM »
Dave,
  I think the Nats is out at this point.  :walkaway:
Offline purple1
« Reply #3 on: July 15, 2007 - 10:01:55 AM »
Dave,
How bad do you want it...  :poopoke: I have a BB trans... To you $300.  :money:
Dave :wave:
« Reply #4 on: July 15, 2007 - 11:21:03 AM »
Having your carb off could this be a kick-down linkage issue?!?!?!
Offline ViperMan
  • 2017 Carlisle or BUST...
    • JS Custom Cars
« Reply #5 on: July 15, 2007 - 11:25:18 AM »
"Scary noises" do not usually easily lend themselves to needing just a "thingamajoohickey..."
My first question was going to be fluid level - I was getting some scary noises and delayed shifts from neutral into first, but then I realized the trans fluid was dry - pan bolts had all loosened slightly.
If your fluid is good, then man I dunno...  Rebuild is most likely imminent.
Jeff
Offline purple1
« Reply #6 on: July 15, 2007 - 11:31:17 AM »
 :popcorn:
Dave :wave:
Offline ShelbyDogg
« Reply #7 on: July 15, 2007 - 12:09:51 PM »
Mike,
Still trying to find a reason to not go to the Nats?    Geez..
Get a working valve body and swap yours out for testing.  This will tell you if it has to come out or not.
I hope you didn't pop the rear sprag.
What did you do before it started doing this?
We expect you at the Nats even if you don't bring your car.
Offline camjam
  • Rare-it-T
« Reply #8 on: July 15, 2007 - 01:03:15 PM »
I agree with checking the fluid level.
71 Challenger R/T 383 4spd - 1 of 10 known to have been built for canada - restored
70 Charger R/T SE 440 auto - restored
« Reply #9 on: July 15, 2007 - 01:26:15 PM »
I wish it was the fluid level guys, but my ears tell me otherwise. It sounded like I was dragging something under my car for a while there.   :crying: I think I be $crewed.  :faint: I'll check it again though.  :wave:
Offline tactransman
« Reply #10 on: July 15, 2007 - 04:52:45 PM »
Mike,if you put it in D and 2 and it does not move forward, then you put it in manual low and then it engages,you rolled over the rear sprag. :crying:
Terry-tactransman
Union, Mo.
Offline ShelbyDogg
« Reply #11 on: July 15, 2007 - 05:53:51 PM »
I still want to know what you did to knock out your trans. It had to be shocked hard to kick it out.  Were you trying to do a Shelbydogg burnout?
Offline tactransman
« Reply #12 on: July 15, 2007 - 06:17:57 PM »
A fast idle when putting it in a forward gear will take out the sprag really quick!. :grinyes:
Terry-tactransman
Union, Mo.
Offline ShelbyDogg
« Reply #13 on: July 15, 2007 - 07:54:37 PM »
Mike seems to not be talking about it.
C'mon Mike, tell us what you did while you were testing your carb.
Offline JayBee
« Reply #14 on: July 15, 2007 - 08:00:13 PM »
[/quote]
 :popcorn:
John
1970 Barracuda convertible
2014 Toyota Avalon
