Author Topic: Lower quarter patch panel question....  (Read 3931 times)
Offline 73EStroker
Re: Lower quarter patch panel question....
« Reply #15 on: July 18, 2007 - 12:18:36 PM »
Do the body work properly -  metal with patches, prep and use weld thru epoxy primer and then get a coat of single stage PPG on asap as the epoxy will absorb moisture within a week or so. This will last you about 30years if you look after it like airing out the trunk every now and then and don't use as a daily driver through rain, hail or sleet.
Barry (Salmon Arm)
