Author Topic: 1980 360 Backfires through carb then stalls while in drive.  (Read 3190 times)
Offline dean941
« on: July 19, 2007 - 05:29:47 PM »
1980 - 360 Backfires through carb then stalls while in drive. Kind of like a Pop sounds the engine shuts off immediately and is hard to restart. Ive changed carb, plugs wires, cap,rotor, rans a direct line from a gas can to the carbureator. Yet still the same problem. :stomp: :banghead: I thought the carbureator would solve the problem but it has not................Any suggestions?
Re: 1980 360 Backfires through carb then stalls while in drive.
« Reply #1 on: July 19, 2007 - 05:39:12 PM »
Welcome aboard here Dean.  :wave:
  Sorry about the trouble. It could very well be electrical. Ignition box, or coil?  :dunno: Let me ask you this, when you say it stalls in drive, is this when you first put it into drive, or while driving?
« Reply #2 on: July 19, 2007 - 05:42:33 PM »
My 340/thermoquad did this from early on ..1975..You could ease into it OK but if you poured on the coal ..bang pop chug chug & sometimes would die. Rebuilt carb/replaced everything from plugs, wires, cap, eventually a new carb to no avail....turns out there were a couple of burnt exhaust valves I discovered in '79 when I replaced the heads.. no more backfire..
   I have another story from my moms '74 360 Monaco...similar symptoms that turned out to be the choke spring.
Offline dean941
« Reply #3 on: July 19, 2007 - 06:00:16 PM »
It runs perfectly fine; starts when cold idles fantastic, Drives great....However: It happens randomly while in drive;  while driving down the road (backfires once through carb engine shuts off)...Then after engine is off it wont start up for like 10-20 mins.. You can crank it and crank it and nothing..then 20 mins later starts up and you could drive 10-100 miles till it happens again...Very strange..(Could it be some sort of emmissions control stuff) :hyper: I will try replacing the IGNITION BOX then go from there...
« Last Edit: July 19, 2007 - 06:14:36 PM by dean941 »
Offline vinb
« Reply #4 on: July 19, 2007 - 06:04:47 PM »
If you have one of those Lean Burn Computers on the air cleaner that could be your problem..Its been a long time since I mess with one of those....
Offline dean941
« Reply #5 on: July 19, 2007 - 06:24:37 PM »
Im not sure if it has a lean burn computer on air cleaner; does the 1980 360 come equiped with one...? This is a factory engine all but the basic replacement parts to date..
« Reply #6 on: July 19, 2007 - 06:29:51 PM »
Well the 20 minuite thing makes me think coil....if your gonna throw a part on try that 1st.
Also could be vapor lock in the fuel tank, is your tank vent plugged off?
Offline dean941
« Reply #7 on: July 19, 2007 - 06:38:08 PM »
I will put a coil on and then maybe a ignition box; in the near future, (both about 50 bucks) I have ran the motor with a hose running directly to a gas can with fresh gas and plenty of ventilation. I also Blew compressed air through all the fuel lines back to tank ect. Nonetheless; I am still on square one.
« Last Edit: July 19, 2007 - 06:45:08 PM by dean941 »
« Reply #8 on: July 19, 2007 - 06:48:47 PM »
Everybody needs an extra box...just in case....get a new ballast resistor to, only about $5.00
My car would start most of the time, then I was checking the resistance & voltage for someone here & my #s were jumping all over the place. New ballast & she runs better than ever.
Offline dean941
« Reply #9 on: July 19, 2007 - 07:01:42 PM »
I will try it and see what happens
« Last Edit: July 19, 2007 - 07:22:57 PM by dean941 »
Offline Challenger6pak
« Reply #10 on: July 19, 2007 - 08:11:29 PM »
I agree with Bullitt.  It could be a coil.
Offline dean941
« Reply #11 on: July 19, 2007 - 08:59:38 PM »
Ignition coil or a pick-up coil????Which one do ya think??? :clueless:
« Reply #12 on: July 19, 2007 - 09:16:52 PM »
Ignition coil.
