Author Topic: oil pressure  (Read 623 times)
Offline WVUFELLA
  • (OO/---------\OO) closest i could for a 72
oil pressure
« on: July 20, 2007 - 06:41:55 AM »
Hey guys i ahve a 440 with dome pistons 484 cam and some other small things. I am just now gettin to the point where i can move it around on its own. However i noticed at idle the oil pressure is 20psi of course as soon as you touch the throtlle it shoots up. Would this be becuase of the cam. I thought that with a moderate size cam..... that might cause the engine to lose oil preesure during idle. dont knwo for sure jus what i thought... please send your thoughts... thansk guys
Offline moper
Re: oil pressure
« Reply #1 on: July 20, 2007 - 12:22:15 PM »
The pump is driven off the crank, so the oil pump's volume is dependant on the rpm of the engine. At idle, the pump isnt moving much oil, so the pressure you read is lower. As long as it has 15-20psi hot at idle, and it increases the second the engine revs at all, it's fine.
Offline WVUFELLA
Re: oil pressure
« Reply #2 on: July 20, 2007 - 02:22:44 PM »
hey thanks alot thats what i thought but i wanted to ask the proverbial dumb question just to make sure.
Offline AMXguy
Re: oil pressure
« Reply #3 on: July 20, 2007 - 10:19:26 PM »
 This isn't true on newer engines but the old rule of thumb is 1 lb per hundred RPM + 10 lbs. so at 3500 rpm you should have at least 45lbs, 35+10.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline cudabob496
Re: oil pressure
« Reply #4 on: July 21, 2007 - 12:46:02 AM »
Increase the idle a little
2011 Kawasaki Z1000
