Author Topic: Anyone have a pic of electric washer setup? 72+  (Read 472 times)
Offline Grec
« on: July 20, 2007 - 12:48:56 PM »
Replacing my missing washer setup and have all the parts... only problem is that the brown lead from my wiring harness seems way to short to reach the spade connector on the pump.
Also, I'm assuming the 2nd spade connector is to be grounded to the fender.
Where exactly?
Some good pics of a stock setup would be much appreciated. :-)
Thanks.
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Re: Anyone have a pic of electric washer setup? 72+
« Reply #1 on: July 20, 2007 - 01:17:19 PM »
the ground wire can ground on the tank mounting screw , you may have to extend the brown wire , I have no idea why it would be short unless the wires are routed the wrong way
Offline Grec
« Reply #2 on: July 23, 2007 - 09:57:08 AM »
I'm pretty sure I have it routed right.
Routed right along the pass-side valve cover along with alternator, distrubutor and temp sensor wires and then routed behind the alternator using that rubber-dipped wire holder thingy.
- 440 Six Pack
« Reply #3 on: July 23, 2007 - 11:00:16 AM »
sounds correct to me
