Author Topic: Seat Belt Lengths  (Read 847 times)
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
Seat Belt Lengths
« on: July 22, 2007 - 12:21:31 AM »
Does anyone know the correct length of the front and rear seat belts (lap belts) for a 1970 Challenger Convertible?  Obviously, there are no shoulder harnesses.  Don't need to know the length of the retractor belts as I have originals that are untouched, but if this info can also be provided, I would greatly appreciate it.  I need to have my belts remade with the correct 4 rib design and material thickness.  Can anyone recommend  someone for this ?  Thanx.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline r15303
Re: Seat Belt Lengths
« Reply #1 on: July 22, 2007 - 12:32:17 PM »
 :popcorn:
Offline filmsurgeon
« Reply #2 on: July 24, 2007 - 03:53:14 AM »
Can anyone help with this request?
Offline filmsurgeon
« Reply #3 on: July 28, 2007 - 08:36:18 PM »
Well, if no one knows the answer to this, can any one direct me to a source where I might get the answer?  Thanx.
Offline gkring
« Reply #4 on: July 28, 2007 - 10:12:44 PM »
www.ssnake-oyl.com
never heard a complaint about them except the price. Haven't seen a cheap source for original or restored seatbelts. Plenty of aftermarket sources, but since you mentioned number of ribs and lengths I assume you want originality?
Greg
1970 Barracuda driver
Offline filmsurgeon
« Reply #5 on: August 11, 2007 - 02:22:10 AM »
Does anyone know the correct length of the belts for the front seat retractors for a 70 challenger?  I have seen ads for 13" and 18" length retractor belts.  Thanks.
