Author Topic: speedo help  (Read 953 times)
Offline pink panther
speedo help
« on: July 22, 2007 - 12:48:38 PM »
coming back from a show yesterday the speedometer quit working. It would show speed and bounce around a little bit, only about 5mph or so up from the actual speed. then it quit working all together. I have had some electrical issues latley, but suspect it is the cable.  Is there a way to tell if it is the cable before changing it? Any other ideas where to look for the problem?
any help would be greatly appreciated.
Re: speedo help
« Reply #1 on: July 22, 2007 - 12:59:32 PM »
It could be either the cable or the guage itself , the speedo is not electric so my guess is the guage , check the cable first to be sure it is not broken , if not then spin the cable in the back of the guage & see if the guage still moves , the guage may need cleaning & lubricating
Re: speedo help
« Reply #2 on: July 22, 2007 - 06:41:48 PM »
got it, the cable had come off on the back of the speedo, probably when I was tracing and messing with all the wires on my electrical issues.  Guess driving it for awhile it vibrated completley off.
Thanks Chryco
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
Re: speedo help
« Reply #3 on: July 22, 2007 - 06:52:37 PM »
Speedometer cable should not come off of the speedometer. It has a locking tab on the end of the cable. If the tab is broken off you need a new cable, or it will fall off again.
Dave :wave:
Worlds first e-body trailer.    Severna Park, Maryland
Re: speedo help
« Reply #4 on: July 22, 2007 - 07:20:43 PM »
Dave :wave:
Yeah Dave,
the speedo cable has a clip, but the back of the speedometer doesnt have anything to clip into, it is just a shaft out of the back of the guage.  What is it? is it anorhter plastic piece that goes on the speedo shaft?
Offline purple1
Re: speedo help
« Reply #5 on: July 22, 2007 - 08:26:14 PM »
Yeah Dave,
This is a rallye cluster, but all speedometers should have a ridge that the tab locks on to.
Dave :wave:
« Last Edit: July 22, 2007 - 08:28:37 PM by purple1 »
Re: speedo help
« Reply #6 on: July 23, 2007 - 09:34:57 AM »
yeah I have the rally cluster, I will look at it again as it is dark looking up from the floor board.
Thanks for your help.
Offline purple1
Re: speedo help
« Reply #7 on: July 23, 2007 - 02:52:23 PM »
No problem, You may just have to push a little harder to get it to click into place. Good luck.
Dave :wave:
Re: speedo help
« Reply #8 on: July 23, 2007 - 04:07:25 PM »
You have to push in on that clip to get it to release, so try pushing in on it as you try to install it.  :dunno:
Re: speedo help
« Reply #9 on: July 23, 2007 - 04:10:54 PM »
Will do Mike.
