Author Topic: rocker arm oil question  (Read 733 times)
Offline WVUFELLA
  • (OO/---------\OO) closest i could for a 72
« on: July 24, 2007 - 11:46:56 AM »
hey guys is it possible to put the rockers that are supposed to go on the drivers side on the pass side and vice versa. I looked in my valve covers and it didnt seem like there was much oil laying in there. I was wondering if by chance i switched those two around..... or if there is not alot of oil that passes thru there ..... or i guess a better question is how could i look and check to see if i switched them.... is there supposed to puddles of oiil laying there or just oil trickling thru??
Re: rocker arm oil question
« Reply #1 on: July 25, 2007 - 11:11:53 AM »
the oil to the rockers is limited , it should be wet but no puddles of oil , you can install either shaft on either head but the offset rockers cannot be reversed on the shafts
