Author Topic: 4 speed questions?????  (Read 709 times)
Offline challenger71
« on: July 25, 2007 - 07:19:16 AM »
I have two questions here. First, is a 3 speed small block bellhousing the same as a 4 speed small block bellhousing? Second, will a 1982 A833 with both shifter mounting spots on the tailshaft work in my 1971 Challenger? I wasn't sure if all years would work or not.
10 years in the making......
Offline Pistol Gripper
Re: 4 speed questions?????
« Reply #1 on: July 25, 2007 - 08:23:01 AM »
The bellhousing should have mounting holes for both the 3 & 4 speed.  The tranny should bolt up.  Here's a good resource for info:
http://www.slantsix.org/articles/4-speeds/ODA833fourspeed1.htm
P.G.
O ne
B ig
A $$
M istake
A merica
« Reply #2 on: July 25, 2007 - 11:17:58 AM »
the 80s 833 will boltin no problem , I do it all the time , but it will be an overdrive version , you will need to bend 1 shift rod slighty to work , generally you will need to either cut the brg retainer down to 4.80" or open the bellhousing up to fit the front brg reatainer
