Author Topic: Correct way to ground an engine with an aluminum six-pack intake...?  (Read 667 times)
Offline Grec
JUst to be sure my electrical problems aren't being caused by a bad ground, here's my current setup:
Negative cable from battery is connected where the throttle bracket bolts to the intake. I've got the bolt, negative cable, throttle bracket, intake.
I know the aluminum intake won't ground properly, but I had assumed that the negative cable would be grounding through the bolt to the block.
This sound right?
When I set it up initially, I was going off of pics of 70-71 six-pack setups, forgetting that these cars originally had iron intakes.
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Re: Correct way to ground an engine with an aluminum six-pack intake...?
« Reply #1 on: July 25, 2007 - 10:04:50 AM »
That isn't an issue as aluminum can conduct electricty reasonably well. However, do you have a block to chassis ground strap in place? You usually find it on the passenger side from the cylinder head to the firewall. Without it you are at risk as it is possibly to isolate the engine from the chassis. Unlikely, but possible with rubber motor and trans mounts , bushed linkages and rubber hoses.
Offline Grec
« Reply #2 on: July 25, 2007 - 05:54:50 PM »
Thanks, and I'll check on that other ground.
I didn't know I was supposed to have another one aside from the one at the intake manifold.
- 440 Six Pack
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« Reply #3 on: July 25, 2007 - 09:19:12 PM »
anyone have a pic from  a '70 challenger bblock firewall ground strap?
Don't remember seeing one.... :dunno:
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
