Author Topic: Holley Choke Gaaaaaak  (Read 2744 times)
Offline Challenger6pak
Re: Holley Choke Gaaaaaak
« Reply #15 on: July 27, 2007 - 11:35:31 PM »
OK now I see.  You are looking for the manifold choke pull off mechanism.  I thought you were looking for the choke on the carb.  Is this what you are looking for?  The pull off is the same part number for Holley 2 bbl and 4 bbl.  Carter also used the same pull off.  It has a z shape to the rod.  The rod can be bent and this causes the adjustment.  I think FY1challenger is correct.  You will just need to play around with the carb spacing until you get things to fit. Here's a pic and link.
http://cgi.ebay.com/ebaymotors/MOPAR-1970-1971-1972-HOLLY-2BBL-Choke-Thermostat-NEW_W0QQcmdZViewItemQQcategoryZ33552QQihZ019QQitemZ290142138440QQrdZ1QQsspagenameZWDVW
« Last Edit: July 27, 2007 - 11:44:33 PM by Challenger6pak »
Offline FY1Challenger
  • I'm a llama!
« Reply #16 on: July 30, 2007 - 01:40:20 PM »
"There used to be a guy in Augusta, GA, Merv Harden, that sold these chokes on e-bay, that's where I was able to get mine." Uhm, lets try this again...the choke you want based on your pics and description is the one I described in an earlier reply. Instead of having a Carter part # on the dome it says Holley and has a different style rod to accomidate the Holley carb. ??? Your carb spacing looks fine.
