I'm not to this point yet, but almost ready to buy the 6.1 (just waiting to see if Mopar releases the 392/6.4L long block) first.
Rembember the computer (ECU/ECM....) is the tough part of the combo. Those prices for the 6.1 do not come with the computer and will not run. You'll need to either get the factory computer and harness and reflash the computer for performance mods, security and a few other things. BG Performance seems to be the leader in this right now.
If not the factory computer, then FAST or AEM has systems out for the engine. Not totally plug and play though. You'll need to tune it on a laptop/dyno/road and dial it in. FAST makes a drive by cable throttle body kit and so does Street and Performance. Several companies make harnesses. If you run a carb with the XV manifold you'll still need to manage the spark with either a FAST or MSD type ignition controller that will tie into the crank sensor and coil on plug system.
The fuel and ignition is the biggy on this swap.
Rick's Hot Rod and Tanks makes a really nice stainless bolt in pump in tank with sump for about 800 or so. Really nice set up. Otherwise you will usually need to modify the tank with a sump kit, pump, supply and return lines for the EFI, etc.
XV is coming out or has out a radiator and fan for the combo, but several others do or can make one.
TTI or XV headers. TTI makes them specially for the AlterKation or no torsion bar fronts too. Both are expensive if you go this route. I hear you can use the stock manifolds with some work.
The crate 6.1s do not come with the front drive/accessories either so figure another grand for those parts too.
I'm definitely going this route with my in progress Challenger, but again this has just been research for me and I do not have the hands on with this combo so if I'm wrong on a few things......sorry. I'm speaking from the armchair only!
Wes
