Author Topic: New E body steering wheels from Grant  (Read 12942 times)
Offline Challenger6pak
Re: New E body steering wheels from Grant
« Reply #15 on: July 29, 2007 - 07:24:39 PM »
Mike, Hopalong was talking about the factory tuff wheel.
Offline matt63
« Reply #16 on: July 29, 2007 - 09:44:14 PM »
The Grant Tuff wheel just bolted right on to the can where my stock 2 spoke wheel sat.  At $100 it's a great buy!
Matt in Edmonton
'68 Valiant
« Reply #17 on: July 30, 2007 - 05:26:45 AM »
My bad.   :misbehaving:
Offline crcarch
  • Happiness is having the time and the money!
  • "No, it's not a Charger!"
    • A little history and restoration pics on Cardomain
« Reply #18 on: July 30, 2007 - 08:55:05 AM »
Are those wheels a smaller diameter than the stock black/woodgrain wheel?
Also, did you guys see that XV has come out with a new tilt column specifically for the E-body.  Sure would help with "nut cruncher" position on the OEM wheel.
00/===\00 73 Challenger 440-4V/AT  8/--+--\8 09 Ram 1500  0o\==/o0 05 Crossfire Roadster OO(#####SRT)OO 10 Challenger
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« Reply #19 on: August 07, 2007 - 02:38:28 AM »
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=160144151874&fromMakeTrack=true&ssPageName=VIP:watchlink:middle:us
would my stock '70 Challenger crushcan (black spoke/woodgrain wheel) accept this new wood wheel without an adapter?
I seem to hear yes and no in this thread
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
Offline gkring
« Reply #20 on: August 07, 2007 - 03:23:08 PM »
MINE WILL BE HERE TOMORROW. I have a three spoke wheel and am replacing with the grant wood tuff wheel.
That's a good price on the ebay ad. I paid $160 delivered from Summit racing and had to wait a coupel weeks because they keep backordering.
Greg
1970 Barracuda driver
« Reply #21 on: August 07, 2007 - 03:56:50 PM »
The answer is "yes and no". The wheel fits fine. I had to buy a horn switch kit for it though. The Grant wheel isn't like the Mopar wheel under the horn button.  I paid someone on E-Bay $149 for my wheel, plus another $29.95 for the adapter kit... most of the parts of which I didn't need.
Offline gkring
« Reply #22 on: August 08, 2007 - 12:20:30 PM »
Just received it.
Not as good looking as the pictures. The wheel has a more natural finish, no clearcoat or varnish on the wood so it is kind of dull. The rivits we could also do without. It comes without a horn switch, so you can either use a tuff wheel or the ones out of their adapter kit. I haven't installed it yet, but I assume some fabbing will be needed to use a Grant horn switch with a non tuffwheel crush can. I think I'll keep it. Grant does have much better looking wood wheels, but since this one has the Tuff wheel flavor it looks more correct to me. I'll get some install pics up in a day or two when I have time to actually mess with putting it on.
Greg
Offline IMNCARN82
  • LeDZeP
« Reply #23 on: August 10, 2007 - 06:43:10 PM »
These are very cool steering wheels.    Can't wait for more pics!!    I'm think'n the black on too :dunno:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline gkring
« Reply #24 on: August 12, 2007 - 10:55:17 PM »
Before pic, standard 3 spoke wheel
« Last Edit: January 27, 2013 - 02:34:43 AM by gkring »
Greg
Offline gkring
« Reply #25 on: August 12, 2007 - 10:56:32 PM »
three spoke wheel compares to Grant 246 wooden Tuff wheel
original wheel is about an inch bigger diameter, dish is about the same, all mounting holes match up exactly
« Last Edit: January 27, 2013 - 02:35:15 AM by gkring »
Greg
Offline gkring
« Reply #26 on: August 12, 2007 - 11:13:08 PM »
Here's the only "tricky" part. You can use your existing horn switch. It screws right into the new tuff wheel. However the Grant supplied horn pad will not snap onto the three spoke horn switch.
The three spoke horn switch has a center hole diameter of 1.3125 (1 5/16).
The Grant horn pad is designed to snap into a 1.375 (1 3/8) hole. I assume a tuff wheel horn switch is this size.
Grant is nice enough to supply an adapter horn ring to be used with their $30 install kits.
I see no reason to buy their install kit just to get a horn switch that you still have to "make work" just to use an adapter on top of another adapter.
I got out the unibit and opened my horn switch up to 1.375, a dremel or die grinder would do the same thing. You can not shove the horn pad on without opening up the hole. Better to go a little bigger than smaller. The retaining ring on the horn pad is just glued on, so if the hole is too small and tight you may rip it off next time you need to remove it. I test fitted mine before putting the wheel on and had to knock it loose from the backside with a screwdriver and enlarge the hole slightly with a Dremel.
« Last Edit: January 27, 2013 - 02:35:52 AM by gkring »
Greg
Offline gkring
« Reply #27 on: August 12, 2007 - 11:16:25 PM »
Rim bolted up, ready to put on horn pad. About a 20 minute deal from start to finish, including the custom fitting.
« Last Edit: January 27, 2013 - 02:36:38 AM by gkring »
Greg
Offline gkring
« Reply #28 on: August 12, 2007 - 11:27:38 PM »
Horn pad snapped on, finished!
Still would rather have it without the rivits, but it looks a hundred times better than a worn out plastic/wood rim.
If you have leg or gut clearance problems with your three spoke you are going to have the same issues with this wheel. Luckily I don't have that issue, but have heard plenty of concerns in this area so I figured I would pass it along.
« Last Edit: January 27, 2013 - 02:37:11 AM by gkring »
Greg
Offline gkring
« Reply #29 on: August 12, 2007 - 11:28:38 PM »
Last one, side shot. Hope this answers all the questions.
« Last Edit: January 27, 2013 - 02:37:40 AM by gkring »
Greg
