Textured paint for dash
Author Topic: Textured paint for dash  (Read 4392 times)
Offline AARudy
  • 1970 4-speed AAR---71 Cuda conv----70 Chall 440-6
Re: Textured paint for dash
« Reply #15 on: July 31, 2007 - 08:59:57 PM »
hey clown, what paint are you using again for the dash pieces??? I like it a lot on that heater control...
Offline AARudy
« Reply #16 on: July 31, 2007 - 09:07:34 PM »
i dont have them for 72-74...i bet their the same colors with different names....?? hard to say...
i think bright blue will look the same for all years....i really dont know..my interior for my AAR is bright blue...if you study the charts above, there are two different blues for the interior...the metal dash is a medium blue and not the bright blue like the other parts....so read all of that tiny print up there, it tells exactly what parts are what blue...
Offline 30below
« Reply #17 on: August 01, 2007 - 09:32:20 AM »
Thanks for your help.My dash pad was rebuilt and dyed at a dash restoration place.I have color matched the door panels[not painted them yet] and have the suade paint from Mopaints for the frame.That chart will help greatly
Offline AARudy
« Reply #18 on: August 01, 2007 - 05:45:27 PM »
send a couple pics when you get the frame painted...if you can..thanks! :dogpile:
Offline moparclown
« Reply #19 on: August 01, 2007 - 06:24:47 PM »
Hey Rudy
The paint is rustoleum texture finish with a satin finish sprayed over top of the texture finish.I don't consider it a very close resembelence to the factory looking wrinkle finish.And I am working on an Idea,using my airbrush and some lacquer reducer sprayed at a fresh enamal.I don't know if it will work?but anytime lacquer got near any enamel it wrinkled.It's just tough to make it controllable,to get the right finish.--The Clown
Offline Lunchbox
« Reply #20 on: August 01, 2007 - 06:57:36 PM »
Do you use a adhesision promoter before you paint?
Lunch
Offline moparclown
« Reply #21 on: August 01, 2007 - 08:53:00 PM »
I just scuff and primer and then paint
Offline 30below
« Reply #22 on: August 02, 2007 - 07:55:06 AM »
Rudy,a little more practice painting some other things before i paint the frame.That stuff is to expensive to screw up,and will send picks
Offline JayBee
« Reply #23 on: January 19, 2008 - 01:32:49 PM »
Tried this stuff on a couple pieces. "Harley Davidson Wrinkle Finish". Cost about $30.00cdn and is a pain to work with. I have to re-strip the heater control bezel and do it again. Temperature and application seem to be pretty critical but the end result is really quite close. Maybe the pics don't show that but in person it looks good and my buddy at his resto shop thought so too.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline FJ5_440
  • Wisconsin
« Reply #24 on: January 29, 2008 - 11:12:04 PM »
That looks pretty good in the photos.  Except for the $30 a can. I would get a can of that just to practice with.
** Shane **
Offline 73Chally
« Reply #25 on: January 30, 2008 - 08:37:01 AM »
That heater control panel looks really good.  I have one that is showing the same mottling on the front as your 'before' picture and so far TSP and a toothbrush have no effect.  What did you use for cleaning and prep of the visible plastic?
Thanks!
I actually just did mine this weekend, and soaked it in regular brake fluid for about 12 hours.  After that, I just pretty much used my fingers to wipe the texture off, and a brush to get the corners and raised letter areas.  It worked great.  After soaking and wiping, just rinse it in a dish soap / water bath for a couple minutes.
« Reply #26 on: January 30, 2008 - 09:41:05 AM »
Heater & radio bezels on my 73 challey the finish is rough. I used Rusoleum textured black found at Lowes. Was a dead match!
http://www.rustoleum.com/Product.asp?ddf=197&frm_product_id=20&SBL=1
Offline Challenger_7
« Reply #27 on: February 08, 2008 - 04:04:37 PM »
Hi, I know I am coming in late to this but only just saw it, too busy with my own !!
Where I am, we cannot get textured paint, and still the idea of textured paint still seems to me as a fragile solution, if one can get the tecture back on from the plastic itself, for a few cents only !!
Please visit my restoration thread and see how easy you can bring everything back on. go to:
http://www.cuda-challenger.com/cc/index.php?topic=40611.75
Its is worth it :lol:
71 Chally Conv 383 Magnum Manual - Hurst
71 Chally Auto 383 Magnum R/T 100% Orig
71 Chally Auto 400
70 Chally Auto small block
72 Charger SE Manual - Hurst
73 Plymouth Satellite "Sebring Plus" 100% Orig
Others: http://www.cardomain.com/id/Challenger_7
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #28 on: February 09, 2008 - 07:07:38 AM »
Thank You for posting the color charts thats great info....
 :cooldancing:
Go Fast & Have Fun...
