Author Topic: Lower Fender Bolt Pic  (Read 660 times)
Offline mickey
« on: July 31, 2007 - 07:39:37 AM »
Hi.
      Would anyone have a pic of lower fender bolts behind front tire. If I remember correctly it was a 5/16 stud to clip and the shims?
Another fender question, trying to jog my mind,,inner fender wells, three studs & nuts above the tire, the outer two were bolts. with washer like Shims or no Shims?
        Thanks
Offline RUSTY Cuda
  • One big step foward!
Re: Lower Fender Bolt Pic
« Reply #1 on: July 31, 2007 - 09:20:19 AM »
Not sure on the size of the stud, but the u nuts were a little beefier on the drop legs then the ones on the fenders, shims are for alignment used as needed.
I believe you are correct on the 3 studs on the inner fender, my cars were taken apart so many times they were mixed up, but all that were there were in that area. sorry one of the few things I have no location pics.  Again the shims are used as needed to line things up.  Rich
